iPhone 11 분해도
crwdns2931653:07crwdne2931653:0
iPhone 11 Teardown: crwdns2935265:00crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 11 Teardown: crwdns2935265:00crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 11 Teardown: crwdns2935265:00crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  • This rectangular battery is held down with a total of six GBs of RAM (Gooey Battery strips), and unfortunately does not share the streamlined removal process that the Pro phones have—to comfortably remove all those adhesive strips, you’re going to have to remove the loudspeaker in addition to the Taptic Engine.
  • That’s not to say that we don’t appreciate the stretch release adhesive—we <3 pull tabs!—but this does complicate the battery replacement process compared to its Pro siblings.
  • This year’s battery measures 40.81 x 96.93 x 3.97 mm, and weighs 44.1 g.
  • Compared to the XR’s battery, the 11's is slightly smaller in size, despite the increased capacity. 3110 mAh is the new spec, which is about a 7% increase. That’s not a huge difference, but it probably accounts for some of the supposed extra hour of battery life the iPhone 11 gets .
  • If you prefer your battery stats in Watt-hours—as we generally do—you're looking at a jump from 11.16 Wh to 11.91 Wh.
  • There’s only one connector on this rectangular battery, but it’s still included in Apple’s new-hardware-that-improves-battery-health document. Maybe that means the twin cables in the 11 Pro were for bilateral charging after all, and there’s some other health-boosting hardware difference in the 11 lineup?
이 직사각형 배터리는 총 여섯 개의 GB (Gooey Battery 끈끈한 배터리 스트립)으로 고정되어 있으며 유감스럽게도 Pro 휴대폰의 간결한 분리 과정은 공유하지 않습니다—모든 접착 스트립을 수월하게 제거하려면 Taptic Engine/탭틱 엔진과 더불어 라우드스피커도 분리하세요.
그러나 우리가 신축성 접착제를 감사하지 않는 것은 아니지만—우리는 당김 탭을 <3 합니다—Pro 형제에 비해 배터리 교체 과정을 복잡하게 합니다.
올해의 배터리 크기는 40.81 x 96.93 x 3.97mm, 무게는 44.1g 입니다.
XR 배터리와 비교할 때 늘어난 용량에도 불구하고 11의 크기는 약간 작아졌습니다. 새로운 사양은 3110mAh, 약 7% 증가했습니다. 대단한 차이는 아니지만 아마도 iPhone 11에 더해진 배터리 용량의 일부를 설명할 것입니다.
배터리 정보를 Watt-hours/와트-시 단위로 선호한다면—보통 그렇듯이—11.16Wh에서 11.91Wh로 상승한 것을 보고 있습니다.
이 직사각형 배터리에 커넥터는 한 개만 있으나 이는 여전히 Apple의 배터리-상태-개선-새로운-하드웨어 페이지에 포함되어 있습니다. 어쩌면 11 Pro의 이중 케이블은 결국 양방향 충전을 위한 것이며 11 라인업에 다른 상태-개선 하드웨어 차이가 있습니까?
