Vue éclatée de l'iPhone 11
crwdns2936317:0crwdne2936317:0
crwdns2931653:07crwdne2931653:0
iPhone 11 Teardown: crwdns2935265:00crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 11 Teardown: crwdns2935265:00crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 11 Teardown: crwdns2935265:00crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  • This rectangular battery is held down with a total of six GBs of RAM (Gooey Battery strips), and unfortunately does not share the streamlined removal process that the Pro phones have—to comfortably remove all those adhesive strips, you’re going to have to remove the loudspeaker in addition to the Taptic Engine.
  • That’s not to say that we don’t appreciate the stretch release adhesive—we <3 pull tabs!—but this does complicate the battery replacement process compared to its Pro siblings.
  • This year’s battery measures 40.81 x 96.93 x 3.97 mm, and weighs 44.1 g.
  • Compared to the XR’s battery, the 11's is slightly smaller in size, despite the increased capacity. 3110 mAh is the new spec, which is about a 7% increase. That’s not a huge difference, but it probably accounts for some of the supposed extra hour of battery life the iPhone 11 gets .
  • If you prefer your battery stats in Watt-hours—as we generally do—you're looking at a jump from 11.16 Wh to 11.91 Wh.
  • There’s only one connector on this rectangular battery, but it’s still included in Apple’s new-hardware-that-improves-battery-health document. Maybe that means the twin cables in the 11 Pro were for bilateral charging after all, and there’s some other health-boosting hardware difference in the 11 lineup?
La batterie rectangulaire est maintenue en place par six bandes adhésives ni plus ni moins. Malheureusement elle ne partage pas la configuration simplifiée des téléphones Pro. Pour retirer confortablement toutes ces bandes, vous allez devoir retirer le haut-parleur ainsi que le Taptic Engine.
Ce n'est pas que nous n'apprécions pas les bandes adhésives d'extraction – nous adorons tirer dessus – mais cela complique le processus de remplacement de la batterie par rapport aux Pro.
La batterie de cette année mesure 40,81 x 96,93 x 3,97 mm et pèse 44,1 g.
Comparée à la batterie du XR, celle du 11 est légèrement plus petite en taille, bien que la capacité ait augmenté. Elle performe à présent à 3310 mAh, ce qui représente une croissance de 7 %. Cela ne fait pas une grande différence, mais permet tout de même à l'iPhone 11 de gagner une heure en autonomie de batterie.
Si vous préférez mesurer les performances des batterie en watt-heures (comme nous avons l'habitude de faire), admirez un saut de 11,16 Wh à 11,91 Wh.
Il y a seulement un connecteur sur cette batterie rectangulaire, peut-être lié au document nouveau-hardware-améliorant-les-performances-de-la-batterie d'Apple. Les nappes jumelles du 11 Pro seraient finalement en rapport avec la recharge bilatérale et il y aurait eu des mesures différentes pour booster la batterie du 11 tout court.
