The camera is attached to the motherboard in your phone. A T6 screwdriver is needed to access the camera.
            Press down the button on the back panel.
            Remove the back cover from the phone.
            Press the silver button on the top of the phone.
            Slide your thumbnail down the case seam to separate the rest of the case.
            Using a T6 Torx Screwdriver, unscrew and remove the six screws shown in the picture.
            Remove the panel that covers the motherboard.
            Locate the camera on the circuit board.
            Place the circuit board on a firm, static free surface (no cloth/carpet).
            NOTE: The circled alignment notch points to the left.
            Pull the left holding tabs to the left.
            Lift out the left side of the camera.
            Pull the right holding tabs to the right.
