projectiondesign GP3 lamp replacement (F3, F30, F32, F35)
  1. projectiondesign GP3 lamp replacement (F3, F30, F32, F35), Lamp doors: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the projector's right side are the two lamp doors, and the security lock hole.
    • Lamps can be removed/replaced while the projector is powered on (it has 2, so the other lamp can continue projection in critical situations). But I suggest doing it with the projector off, and cooled down.
    • Each lamp has a separate door. Unscrew the captive Philips screw at the top of the door and open it.
  2. projectiondesign GP3 lamp replacement (F3, F30, F32, F35), The lamps: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 projectiondesign GP3 lamp replacement (F3, F30, F32, F35), The lamps: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Observe there are 3 plastic thumbscrews per lamp -- two on top and one at bottom.
    • Rotate them 1/4 turn (90 degrees) counter-clockwise to unlock.
    • If they are difficult to turn by hand, a large flat-head screwdriver may also be used.
    • Once all 3 screws are unlocked, grasp the lamp housing from the rear protrusion, and pull. If you feel a lot of resistance, try wiggling the screws to ensure they have released.
    • For the plastic thumbscrews, horizontal is locked, vertical is unlocked.
    • Once the lamp is removed, you can see the three guide pins, which are held by the three thumbscrews.
Lamp hours are recorded on a chip in the lamp itself, so there should not be a timer to reset manually when installing a new lamp.
Compatible part numbers are:
400-0300-00 (GP3 UHP lamp, 250W) or 400-0500-00 (GP3 UHP lamp, 300W).
OEM lamps may be hard to purchase since the projectors have been discontinued.
Installation of new lamps is performed in the reverse order: insert lamp, lock thumbscrews, close doors and tighten each screw.
Dan C
crwdns2935283:007/11/20crwdne2935283:0
670 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 109
