projectiondesign GP3 Lens Replacement (F3, F30, F32, F35)
  1. projectiondesign GP3 Lens Replacement (F3, F30, F32, F35), Types of lens: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 projectiondesign GP3 Lens Replacement (F3, F30, F32, F35), Types of lens: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • PD manufactured many different lenses that fit these projectors. Some that zoom, others that have fixed throw ratios. There are even extra-high-quality ones for the projectors with the most pixels.
    • The website projectorcentral.com lists a few ones for the F35:
    • EN41 Standard Zoom Lens Throw Ratio 1.69:1-2.50:1
    • EN43 Wide Zoom Lens Throw Ratio 1.20:1-1.69:1
    • EN44 Short Tele Zoom Lens Throw Ratio 2.50:1-4.61:1
    • EN45 Ultra Wide Zoom Lens Throw Ratio 0.80:1-1.21:1
    • But these are only some of the ones available from the factory.
  2. projectiondesign GP3 Lens Replacement (F3, F30, F32, F35), Unlock and remove lens: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 projectiondesign GP3 Lens Replacement (F3, F30, F32, F35), Unlock and remove lens: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 projectiondesign GP3 Lens Replacement (F3, F30, F32, F35), Unlock and remove lens: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Begin by pressing and holding the lens-release button with your right hand (or have a helper do this).
    • Apologies for the very dark picture!
    • Grasp the outside barrel of the lens with one or two hands, and start to rotate it counter-clockwise. Be prepared to support the weight of the lens as it is released from the locking mount.
    • It will rotate about 45 degrees -- watch the mark on top of the pictured lens for the start and end points.
    • After rotation stops, slide the lens out of the projector.
    • Be careful again that the back end doesn't drop as it slides out! The lenses are made of many heavy pieces of glass -- the weight can be surprising.
  3. projectiondesign GP3 Lens Replacement (F3, F30, F32, F35), The lens is out!: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 projectiondesign GP3 Lens Replacement (F3, F30, F32, F35), The lens is out!: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This picture shows the view inside the lens cavity. Normally there's a shutter that closes here to protect the optical elements, but that was removed in my projector.
    • You can also see the pogo pins that contact the lens ID PCB here. That will help you find the right orientation when re-installing a lens.
  4. projectiondesign GP3 Lens Replacement (F3, F30, F32, F35), Installing a lens: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before installing a lens, make sure there are no obstructions inside the projector (like the original plastic lens mount protector), and remove any back cover or rear cap on the lens itself.
    • Look at the metal mounting flange inside the projector, and at the tabs on the lens itself. There should be three tabs/slots visible.
    • Two tabs/slots are about the same size -- they'll be on top when the lens slides in.
    • One slot/tab will be about 2/3 the length of the others. That one goes "down" as the lens is inserted.
    • Insert it such that the smallest tab of the lens mount "foot" faces down, make sure the lens is completely seated "in-plane', then gently rotate clockwise about 45 degrees -- you should hear and feel a definite tactile click when it locks into place.
    • Don't force it! If it isn't rotating easily, something must be in the way.
That's it! Not much reason to remove a lens unless you're servicing the projector, or repurposing it. Be careful -- if it's heavy, it's probably expensive. And, cover up the projector's lens mount hole to keep dust and debris out.
Dan C
crwdns2935283:007/11/20crwdne2935283:0
670 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 116
