projectiondesign F35 scheduled maintenance
  1. projectiondesign F35 scheduled maintenance, Lamp doors: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the projector's right side are the two lamp doors, and the security lock hole.
    • Lamps can be removed/replaced while the projector is powered on (it has 2, so the other lamp can continue projection in critical situations). But I suggest doing it with the projector off, and cooled down.
    • Each lamp has a separate door. Unscrew the captive Philips screw at the top of the door and open it.
  2. projectiondesign F35 scheduled maintenance, The lamps: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 projectiondesign F35 scheduled maintenance, The lamps: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Observe there are 3 plastic thumbscrews per lamp -- two on top and one at bottom.
    • Rotate them 1/4 turn (90 degrees) counter-clockwise to unlock.
    • If they are difficult to turn by hand, a large flat-head screwdriver may also be used.
    • Once all 3 screws are unlocked, grasp the lamp housing from the rear protrusion, and pull. If you feel a lot of resistance, try wiggling the screws to ensure they have released.
    • For the plastic thumbscrews, horizontal is locked, vertical is unlocked.
    • Once the lamp is removed, you can see the three guide pins, which are held by the three thumbscrews.
  3. projectiondesign F35 scheduled maintenance, Types of lens: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 projectiondesign F35 scheduled maintenance, Types of lens: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • PD manufactured many different lenses that fit these projectors. Some that zoom, others that have fixed throw ratios. There are even extra-high-quality ones for the projectors with the most pixels.
    • The website projectorcentral.com lists a few ones for the F35:
    • EN41 Standard Zoom Lens Throw Ratio 1.69:1-2.50:1
    • EN43 Wide Zoom Lens Throw Ratio 1.20:1-1.69:1
    • EN44 Short Tele Zoom Lens Throw Ratio 2.50:1-4.61:1
    • EN45 Ultra Wide Zoom Lens Throw Ratio 0.80:1-1.21:1
    • But these are only some of the ones available from the factory.
  4. projectiondesign F35 scheduled maintenance, Unlock and remove lens: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 projectiondesign F35 scheduled maintenance, Unlock and remove lens: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 projectiondesign F35 scheduled maintenance, Unlock and remove lens: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Begin by pressing and holding the lens-release button with your right hand (or have a helper do this).
    • Apologies for the very dark picture!
    • Grasp the outside barrel of the lens with one or two hands, and start to rotate it counter-clockwise. Be prepared to support the weight of the lens as it is released from the locking mount.
    • It will rotate about 45 degrees -- watch the mark on top of the pictured lens for the start and end points.
    • After rotation stops, slide the lens out of the projector.
    • Be careful again that the back end doesn't drop as it slides out! The lenses are made of many heavy pieces of glass -- the weight can be surprising.
  5. projectiondesign F35 scheduled maintenance, The lens is out!: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 projectiondesign F35 scheduled maintenance, The lens is out!: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This picture shows the view inside the lens cavity. Normally there's a shutter that closes here to protect the optical elements, but that was removed in my projector.
    • You can also see the pogo pins that contact the lens ID PCB here. That will help you find the right orientation when re-installing a lens.
  6. projectiondesign F35 scheduled maintenance, Installing a lens: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before installing a lens, make sure there are no obstructions inside the projector (like the original plastic lens mount protector), and remove any back cover or rear cap on the lens itself.
    • Look at the metal mounting flange inside the projector, and at the tabs on the lens itself. There should be three tabs/slots visible.
    • Two tabs/slots are about the same size -- they'll be on top when the lens slides in.
    • One slot/tab will be about 2/3 the length of the others. That one goes "down" as the lens is inserted.
    • Insert it such that the smallest tab of the lens mount "foot" faces down, make sure the lens is completely seated "in-plane', then gently rotate clockwise about 45 degrees -- you should hear and feel a definite tactile click when it locks into place.
    • Don't force it! If it isn't rotating easily, something must be in the way.
  7. projectiondesign F35 scheduled maintenance, Case screws, pt.1: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 projectiondesign F35 scheduled maintenance, Case screws, pt.1: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 projectiondesign F35 scheduled maintenance, Case screws, pt.1: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After removing bulbs and lens, we finally get to open up the projector.
    • There are 11x T10 screws holding the upper case on.
    • 3 on the right (lamp) side
    • 2 on the left (power) side
    • 3 on the rear
    • 3 on the front (see pic on next step)
  8. projectiondesign F35 scheduled maintenance, Case screws, pt.2: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Here are the last screws, on the front: 3x T10
    • After all the screws are removed, start lifting the case from the left and right side.
  9. projectiondesign F35 scheduled maintenance, Removing the case lid: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 projectiondesign F35 scheduled maintenance, Removing the case lid: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 projectiondesign F35 scheduled maintenance, Removing the case lid: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The shell may resist being lifted off. Wiggling it gently will help, but it may also be catching around the silver lens shroud, which is a separate part.
  10. projectiondesign F35 scheduled maintenance, Under the hood: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 projectiondesign F35 scheduled maintenance, Under the hood: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The inside of the plastic shell has a metallic coating, which gives an attractive shiny copper sheen. Set the lid aside for later -- let's get our bearings inside!
    • Lamp house (2 lamps inside)
    • Lamp driver (1 for each lamp)
    • Light path -- color wheels and combining prism -- under this PCB
    • Image engine (including DLP device)
    • Power supply
    • Rear I/O panel and LCD
    • Careful, though -- the coating means the inside is conductive. So, do not remove or replace the lid while the projector is connected to power!
  11. projectiondesign F35 scheduled maintenance, PCB IO (above light path): crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 projectiondesign F35 scheduled maintenance, PCB IO (above light path): crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 projectiondesign F35 scheduled maintenance, PCB IO (above light path): crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To reach the color wheels, we must remove the lamphouse cover. This PCB doesn't actually have to be removed, but all the wires going to it must be disconnected.
    • PD was very considerate in manufacturing these projectors -- there are labels on the cable and on the PCB connector.
    • Starting at the large ZIF ribbon cable, and naming them clockwise, we have: IO card ribbon cable, DC POWER IO, Fan Main, IR, Fan Ctrl VDI, Fan Lamp Driver, [lamp blower fan], Temp Lamp, Lamp Memory, Lamp 2 (switch), CW2, color wheel 2 ribbon, color wheel 1 ribbon, CW1, Lamp 1, Lamp Memory, Temp Out, [lamp 1 blower fan], Fan Lamp Driver, LMP Ctrl VDI, IR2
    • Well, most of my cables were well-labeled. Some, though, are close together enough and similar enough to possibly be confused. So, I suggest labeling connector and cable with marker to distinguish them. See example in pic 3 -- these are ribbon cables for the color wheel motors, and the 3-wire connectors for the position sensors.
  12. projectiondesign F35 scheduled maintenance, Lamphouse and light path covers: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 projectiondesign F35 scheduled maintenance, Lamphouse and light path covers: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 projectiondesign F35 scheduled maintenance, Lamphouse and light path covers: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are 2 ventilated metal covers here, held down by 7 screws total. The IO PCB does not have to come out, but makes it a little easier to reach the screws.
    • 4 screws in the color wheel /light path cover (at the top in the photo), and 3 in the lamp house cover (at bottom in photo).
    • If you choose to remove the IO PCB entirely, these 5 standoffs are where the PCB screws go.
    • As you lift off the lamphouse cover, carefully work around these two wires -- for the lamp hour chip readers. They connect to boards below the cover -- it's probably better to leave them connected to the IO PCB, and unplug the connectors circled here instead.
    • The color wheel bracket is held down by just 3 T10 screws -- but they're about 14mm long and tricky -- especially the middle one, where you must reach through a hole in this black plastic gusset. I suggest using screwdriver with a magnetic tip here.
    • Once these 3 screws are removed, the color wheel bracket will be wobbly and loose. Lift it up carefully -- the wheels are very thin optical glass.
  13. projectiondesign F35 scheduled maintenance, The color wheels!: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 projectiondesign F35 scheduled maintenance, The color wheels!: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The color wheels are mesmerizing optical glass filters. These are the "VizSim Bright" variant. They appear to reflect in a primary color (red, green, blue) but transmit light in secondary (yellow, cyan, magenta).
    • Printing on the ribbon cables suggests these were made by EIS Optics, which was assimilated by Materion, who still makes color wheels and other projector components.
    • The color wheels can be detached from the brackets -- the back unscrews with a pair of needle-nose pliers, or a specialized spanner -- but I did not have the tools to do that yet.
  14. projectiondesign F35 scheduled maintenance, Rear interface panel: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 projectiondesign F35 scheduled maintenance, Rear interface panel: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 projectiondesign F35 scheduled maintenance, Rear interface panel: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The video and control inputs, buttons, and LCD display are all part of one assembly. To remove it:
    • This brown ribbon cable handles all the data going to and coming from this board. Disconnect it gently from the rear panel - a plastic spudger tool can help with this.
    • There is a Molex-style power connector. Depress the lock tab, and pull it out.
    • Now, lift the interface board up. It might bind on the right side where it fits into a plastic tab on the projector bottom.
  15. projectiondesign F35 scheduled maintenance, Lamp driver fans: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 projectiondesign F35 scheduled maintenance, Lamp driver fans: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 projectiondesign F35 scheduled maintenance, Lamp driver fans: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are two lamp driver boards, one in the front and one in the back. These provide high voltage and starting current for the lamps. Each one has a square fan mounted to a bracket.
    • Remove 2x T10 screws holding each fan bracket.
    • Two cables are held in each fan bracket's cable clips. One is for the fan, but the other one needs to be disconnected and slid out from the clips.
    • The fans are held in their brackets with four plastic push-rivets. These can be pushed out from the back with a screwdriver or small punch -- if you are careful, they can be reused to mount the new fans.
  16. projectiondesign F35 scheduled maintenance, Lamp driver PCBs: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 projectiondesign F35 scheduled maintenance, Lamp driver PCBs: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The lamp driver PCBs do not have to be removed, but all wires need to be disconnected. Each board has:
    • A 2-pin low voltage connector from the power supply
    • A small 3-pin connector, on the vertical daughter board
    • A 2-pin white connector, carrying high voltage into the lamps.
    • I suggest tucking the white lamp connector back inside the lamp house to keep it out of the way.
    • If removing the PCB, each one is held by 4x T10 screws.
    • The front driver PCB has a plastic insulator on one of its mounting screw posts. Be careful to not lose it!
  17. projectiondesign F35 scheduled maintenance, Power supply, pt.1: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 projectiondesign F35 scheduled maintenance, Power supply, pt.1: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 projectiondesign F35 scheduled maintenance, Power supply, pt.1: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect 2 Molex-style power cables. If it's too difficult to reach them, wait until you've got all the screws out and are starting to lift the power supply away.
    • Undo 2x black T10 screws
    • Undo 1x silver T9 screw, at the top
    • There are a couple more notes before removing the power supply -- see next step.
  18. projectiondesign F35 scheduled maintenance, Power supply, pt.2: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 projectiondesign F35 scheduled maintenance, Power supply, pt.2: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There is a 4th screw tab on the power supply, but my unit had no screw here. Your experience may differ.
    • Tilt the power supply out slightly, to clear the bracket at the top, then slowly lift up to remove.
    • It may help to bend the plastic bottom shell of the projector away, gently, to help free the main AC power socket.
    • When lifting the power supply out, pay attention to the rear screw tab. It's sharp metal, and is very close to the back of a large PCB. Don't scrape it (or worse, knock small components off)!
    • To remove the heart of the projector, three sets of screws must be removed.
Dan C
crwdns2935283:007/11/20crwdne2935283:0
670 crwdns2915208:0crwdne2915208:0
Dan C I have the optix but lamp 2 have error factory don’t support the model already .
Lamp 2 at menu section show the remain lamp span but it not working . I’m no clue which part is spoil .
Any repair advise or repair shop u know I can send to ?
oto88888 - crwdns2934203:0crwdne2934203:0
Can you switch Lamp 1 and Lamp 2? Does the error follow the lamp, or stay with lamp bay #2?
If it is always lamp bay #2, I'd open it up and make sure all the cables for that lamp are connected. Maybe look to make sure cable pins aren't bent.
If that is OK, maybe it is the color wheel, or a fan, or the lamp igniter (ballast). Best to check what the exact error is for next steps.
Dan C - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 299
