plantronics Voyager pro Battery Replacement
crwdns2936621:0crwdne2936621:0
  1. plantronics Voyager pro Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • order your battery
  2. plantronics Voyager pro Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • separate rubber case from back of earpiece. you don't need to remove it completely like I did.
    Cracked the case open with an exacto blade and a small flathead screwdriver
    Richard - crwdns2934203:0crwdne2934203:0
  3. plantronics Voyager pro Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • rotate the back away from the case. its basically glued in place with no other fasteners
  4. plantronics Voyager pro Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • you will need to slowly cut through the foam to separate the wires from the battery. then use a soldering iron to desolder the old battery from the board these connections go through the entire board.
  5. plantronics Voyager pro Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • solder the new battery in and test the charging before reassembly.
    • the new battery I ordered was slightly larger but it fit with no problems. I found the wires inside this device to be fairly robust and did not have any issues with wires breaking or dislodging.
    • When I re-assembled I used small amounts of gorilla glue for both the case and the rubber cover. it worked very well and has worked well since. for more details I put together a short video you can check out.
Dan Dunham
crwdns2935283:004/15/17crwdne2935283:0
3,507 crwdns2915208:0crwdne2915208:0
crwdns2935297:030crwdne2935297:0
I accomplished this battery replacement. I was successful. However in my opinion, this device was not meant to have this repair done. It is a “fiddley” affair, but possible. I think it took me two hours, at my leisure. Probably better off replacing the device. Unless…. your just that type who enjoys fiddling around.
Leslie Womelsdorff - crwdns2934203:0crwdne2934203:0
I have 2 of these type headsets that I bought as refurbs. They both lasted less than a year...cheap batteries I'm thinking. The process from Dan looks to be a moderate repair. I am going to give it a go because I like to fix things and will write back if I complete the process!
crwdns2936753:030crwdne2936753:0 59
crwdns2942667:0crwdne2942667:0 5,596
