iyashi footrest Disassembly
  1. iyashi footrest Disassembly, Footrest: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iyashi footrest Disassembly, Footrest: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iyashi footrest Disassembly, Footrest: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • remove the 4 screws on the top and the bottom of the plastic cover .
    • This half front panel will need to be removed by sliding it up and off . BE CAREFUL AS THIS PANEL IS EASY TO BREAK.
  2. iyashi footrest Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iyashi footrest Disassembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4 screws .
    • Remove the 5 screws on each edge of back panel.
  3. iyashi footrest Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iyashi footrest Disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iyashi footrest Disassembly: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • remove the wire harness by unscrewing the zip tie . DO NOT CUT THIS ZIP TIE
    • separate this cable from the harness.
    • When removing the rest of the back cover you need to thread this wire through the marked opening .
  4. iyashi footrest Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iyashi footrest Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once back cover is remove this what you should see
    • Next lay footrest down and remove the 4 bolts marked.
  5. iyashi footrest Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all 10 screws.
    • From here remove the bottom panel completely and turn the footrest back in the upright position.
  6. iyashi footrest Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iyashi footrest Disassembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4 bolts with their metal and rubber washers.
    • The top left bolt may be cover by the sensor. To move the sensor , remove the 2 screws marked.
    • Grab the support bar and Motor track . Lift UP until clear of the plastic plate. Alternatively you can grab and lift by using the axle pins .
    • DO NOT PULL THIS ASSEMBLY TOWARDS YOU WHILE LIFTING IT OUT. THIS WILL RESULT IN DAMAGE. ONLY LIFT UP.
    • You can't remove this assembly until bottom panel is removed first
  7. iyashi footrest Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iyashi footrest Disassembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iyashi footrest Disassembly: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all 8 screws .
    • This image is another iteration of the panel, if you see this panel remove the 8 screws marked
    • Fold leather piece down and remove the 4 screws.
  8. iyashi footrest Disassembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This what you should see after back panel is removed. Please lay footrest down again to proceed with next step.
  9. iyashi footrest Disassembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iyashi footrest Disassembly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iyashi footrest Disassembly: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the top 4 screws
    • Slide Axle piece up to remove. PLEASE NOTE ITS POSITION as this will need to be remember during reassembly.
    • Now remove the 4 bottom screws .
  10. iyashi footrest Disassembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iyashi footrest Disassembly: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug both heel switches , and roller assembly should come out with ease.
  11. iyashi footrest Disassembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iyashi footrest Disassembly: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all 15 screws from plastic assembly .
    • Photo doesn't show all 15 screws , but all screws are in the same line through the left , right and middle .
    • Once all screws are removed , Front panel will come off.
Nick
crwdns2935283:005/30/17crwdne2935283:0
2 764 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 62
