ionvac SmartClean V2 Motor Wheel Replacement
  1. ionvac SmartClean V2 Motor Wheel Replacement, Shell (Top & Bottom): crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ionvac SmartClean V2 Motor Wheel Replacement, Shell (Top & Bottom): crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Caution: Before beginning, turn off the ionvac and place it on a level surface.
    • Keep in mind that your ionvac has many small screws that can be easily lost. Using a magnetic project mat is best to prevent misplacing any parts.
    • Flip your ionvac right-side up, turning it so that the front filter vents are facing forward and the power button is furthest from you.
  2. ionvac SmartClean V2 Motor Wheel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ionvac SmartClean V2 Motor Wheel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ionvac SmartClean V2 Motor Wheel Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips screwdriver to remove the 8 screws indicated in red holding the base together.
    • Use the same screwdriver to remove the 8 screws indicated in orange which hold the rims (bumper arms).
    • Remove the rims from your ionvac and set them aside.
  3. ionvac SmartClean V2 Motor Wheel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip your ionvac right-side up and tilt it upwards at a 45 degree angle.
    • Use a Jimmy or prying tool to wedge the sharp end through the bottom crevice (below the sensors).
    • Continue prying the outside rim of your ionvac open. You will feel the top shell (frame or cover) loosen.
    • Caution: Resist the urge to tear the top shell open until the entire rim has been loosened.
  4. ionvac SmartClean V2 Motor Wheel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ionvac SmartClean V2 Motor Wheel Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the top shell off carefully.
  5. ionvac SmartClean V2 Motor Wheel Replacement, Motor Wheel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3 screws securing the cable assembly housing on the outer side of the motor wheel frame labeled either R (right wheel) or L (left wheel).
    • Set the cable assembly housing to the side.
  6. ionvac SmartClean V2 Motor Wheel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ionvac SmartClean V2 Motor Wheel Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the 3 screws securing the motor wheel frame.
    • Dislodge the wheel motor frame from the bottom shelf.
  7. ionvac SmartClean V2 Motor Wheel Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the cable attaching the motor wheel frame to the logic board.
  8. ionvac SmartClean V2 Motor Wheel Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ionvac SmartClean V2 Motor Wheel Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull one end of the spring out of place to remove it from the motor wheel frame.
    • This will separate the motor wheel frame from the motor wheel assembly.
  9. ionvac SmartClean V2 Motor Wheel Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the five screws from the motor wheel assembly.
  10. ionvac SmartClean V2 Motor Wheel Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ionvac SmartClean V2 Motor Wheel Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the clip on the side to separate the casing and expose the white plastic gears.
  11. ionvac SmartClean V2 Motor Wheel Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all but the largest gear to expose the silver screws and washers underneath.
    • Unscrew and remove the two silver screws along with each accompanying set of two washers.
    • Now you can remove the motor from the wheel assembly.
    • To clean the motor, use a soft cloth or alcohol wipe.
Andre
crwdns2935283:009/13/23crwdne2935283:0
175 crwdns2915208:0crwdne2915208:0
University of Colorado Denver, Team 1-1, Campeau Fall 2023 crwdns2935289:0University of Colorado Denver, Team 1-1, Campeau Fall 2023crwdne2935289:0
UCDENVER-CAMPEAU-F23S1G1
crwdns2931471:07crwdne2931471:0
crwdns2935297:011crwdne2935297:0
crwdns2942667:0crwdne2942667:0 541
