iView-776TPCII Wi-Fi Antenna Replacement
  1. iView-776TPCII Wi-Fi Antenna Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iView-776TPCII Wi-Fi Antenna Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iView-776TPCII Wi-Fi Antenna Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before disassembling your device, make sure that the power is completely turned off.
    • Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
    • The clips may take some pressure before releasing.
    • Continue around the entire device until all of the clips have been released.
  2. iView-776TPCII Wi-Fi Antenna Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iView-776TPCII Wi-Fi Antenna Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to carefully free the speaker from it's housing on the back panel.
    • Place the spudger between the speaker and the rear panel. Use a prying motion to remove the component.
    • Be careful not to apply an over amount of force. If care is not taken, the speaker could break under the pressure.
  3. iView-776TPCII Wi-Fi Antenna Replacement, Wi-Fi Antenna: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iView-776TPCII Wi-Fi Antenna Replacement, Wi-Fi Antenna: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the end of the Wi-Fi antenna from the tape on the edge of the shell.
  4. iView-776TPCII Wi-Fi Antenna Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Portable Soldering Iron tool to heat the lead coming from the Wi-Fi antenna to the logic board, thereby breaking the connection.
    • For help on soldering, refer to the iFixit "How To Solder and Desolder Connections" technique guide as necessary.
    • Once heated, use tweezers to pull the wire free from its connection.
Cory Gratzer
crwdns2935283:009/16/15crwdne2935283:0
586 crwdns2915208:0crwdne2915208:0
IUPUI, Team 2-2, Baechle Fall 2015 crwdns2935289:0IUPUI, Team 2-2, Baechle Fall 2015crwdne2935289:0
IUPUI-BAECHLE-F15S2G2
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 535
