crwdns2959928:0crwdne2959928:0 ↓Use this guide to replace the camera on your iView-776TPCII if it is not working properly. In the camera assembly, there are both front and back lenses that must be detached from the tablet shell. There is one ZIF connection to dismantle and it is necessary to desolder connections from the camera assembly to the motherboard.
Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
Continue around the entire device until all of the clips have been released.
Use a spudger to carefully free the speaker from it's housing on the back panel.
Place the spudger between the speaker and the rear panel. Use a prying motion to remove the component.
crwdns2935267:0crwdne2935267:0Heavy-Duty Spudger$4.99
Loosen the edges of the black tape covering the camera using the heavy-duty spudger.
Use the freed edges of the tape to gently remove the camera assembly from its plastic housing.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to lift the cover off the top of the camera's ZIF adapter.
Pull the assembly away from the motherboard with a set of tweezers to prepare for desoldering.
Use the Portable Soldering Iron tool to heat the leads coming from the camera assembly to the motherboard, thereby breaking the connection.
Once heated, use tweezers to pull the wires free from their connections.
