iVIEW-754TPC Digitizer Replacement
  1. iVIEW-754TPC Digitizer Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iVIEW-754TPC Digitizer Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iVIEW-754TPC Digitizer Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before disassembling your tablet, make sure it is powered off.
    • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
  2. iVIEW-754TPC Digitizer Replacement, Remove Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iVIEW-754TPC Digitizer Replacement, Remove Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iVIEW-754TPC Digitizer Replacement, Remove Battery: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use flat side of the spudger to get under battery and use pressure to release from glue. Do this all the way around battery until it comes off.
    • At this point do not attempt to fully remove the battery as it is still attached to the logic board.
  3. iVIEW-754TPC Digitizer Replacement, Camera Assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iVIEW-754TPC Digitizer Replacement, Camera Assembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iVIEW-754TPC Digitizer Replacement, Camera Assembly: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The camera module is located directly under the top right corner of the back cover.
    • Peel back the tape holding down the camera ribbon connector using a pair of tweezers.
    • As you peel the tape backward, the front facing camera may come out, this is not an issue.
    • If the front facing camera does not come out, gently lift it out with a pair of tweezers
  4. iVIEW-754TPC Digitizer Replacement, Remove Camera: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iVIEW-754TPC Digitizer Replacement, Remove Camera: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to lift flap on top of the camera ZIF adapter.
    • At this point the camera module can be easily removed with a pair of tweezers.
    • During reassembly, make sure you put the ZIF adapter snugly back into its socket and secure the flap.
  5. iVIEW-754TPC Digitizer Replacement, Logic Board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 2.2mm Phillips screws holding the logic board in place. Place the screws on the iFixit magnetic project mat.
  6. iVIEW-754TPC Digitizer Replacement, WIFI Antenna: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iVIEW-754TPC Digitizer Replacement, WIFI Antenna: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently peel the WIFI Antenna up using a pair of tweezers.
  7. iVIEW-754TPC Digitizer Replacement, Disconnect LCD: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iVIEW-754TPC Digitizer Replacement, Disconnect LCD: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iVIEW-754TPC Digitizer Replacement, Disconnect LCD: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to lift the flap on top of the LCD ZIF socket.
    • Gently remove the ribbon cable from the socket using a tweezers.
  8. iVIEW-754TPC Digitizer Replacement, Disconnect Digitizer: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iVIEW-754TPC Digitizer Replacement, Disconnect Digitizer: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iVIEW-754TPC Digitizer Replacement, Disconnect Digitizer: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to lift the flap on top of the digitizer ZIF socket.
    • Gently pull the tape attached to the ribbon cable to remove the cable from its socket.
  9. iVIEW-754TPC Digitizer Replacement, Remove Logic Board: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iVIEW-754TPC Digitizer Replacement, Remove Logic Board: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iVIEW-754TPC Digitizer Replacement, Remove Logic Board: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently slide the spudger below the logic board at the left side nearest the battery. Lift upward and away from the power button and bottom connectors.
    • The battery is still attached to the logic board. Be careful to not tear the two apart during removal.
  10. iVIEW-754TPC Digitizer Replacement, LCD: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iVIEW-754TPC Digitizer Replacement, LCD: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iVIEW-754TPC Digitizer Replacement, LCD: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a plastic opening tool between the LCD and digitizer on the side of the LCD with the ribbon cable. Use a second plastic opening tool to lift the LCD from the digitizer. Repeat this process on both sides of the LCD ribbon cable.
    • Fully remove the LCD from the digitizer.
Robert Clark
crwdns2935283:001/21/15crwdne2935283:0
1.065 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 5-4, Brown Winter 2015 crwdns2935289:0USF Tampa, Team 5-4, Brown Winter 2015crwdne2935289:0
USFT-BROWN-W15S5G4
crwdns2942667:0crwdne2942667:0 1,095
