iVIEW-754TPC Battery Replacement
  1. iVIEW-754TPC Battery Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iVIEW-754TPC Battery Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iVIEW-754TPC Battery Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before disassembling your tablet, make sure it is powered off.
    • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
  2. iVIEW-754TPC Battery Replacement, Remove Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iVIEW-754TPC Battery Replacement, Remove Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iVIEW-754TPC Battery Replacement, Remove Battery: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use flat side of the spudger to get under battery and use pressure to release from glue. Do this all the way around battery until it comes off.
    • At this point do not attempt to fully remove the battery as it is still attached to the logic board.
  3. iVIEW-754TPC Battery Replacement, Desolder wires: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iVIEW-754TPC Battery Replacement, Desolder wires: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iVIEW-754TPC Battery Replacement, Desolder wires: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once battery is off, the wires will still be connected to motherboard. You will need to desolder the wires.
    • Using the soldering tool, use the heat to melt the connection. As you do this, pull on the wires with a tweezer until wires comes off.
    • To ease reassembly, take note of which wire goes to the negative and positive terminals.
calvin
crwdns2935283:001/21/15crwdne2935283:0
188 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 5-4, Brown Winter 2015 crwdns2935289:0USF Tampa, Team 5-4, Brown Winter 2015crwdne2935289:0
USFT-BROWN-W15S5G4
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 2,434
