This is a step by step guide on how to replace the battery on an iRobot Roomba i3+ or i3
Unscrew the 5 #0 Phillips screws.
Use a Flathead screwdriver or Philips to unscrew the side brush.
Gently pull the side brush straight up.
Use your fingernails to pull up on each side to remove the cover.
Pull back the clip in the middle and pull the battery straight up.
Line the battery up with the notches and side it in.
To reassemble your Roomba, follow these instructions in reverse order.
