This guide will help you replace the main brushes on the iRobot Roomba e5. Before you use this guide, clean your brushes to make sure that debris was not causing the problem. If your brushes still don't work, then they will need to be replaced.
Release the lock on the brushes using the green tab.
Lift the lock up from the end of the brushes.
