Use this guide to replace the Corner Brush Module on your iRobot Roomba S9+ (Model number: s955020). Be sure to be careful when you’re disconnecting wires. Only pull on solid plastic pieces and not wires. For more information, check out our troubleshooting page.
Place your Roomba upside down with the brush module facing you.
Push the grey tab by the top left corner of the brushes to release the retaining arm.
Lift the retaining arm away from the brushes.
Unscrew the four 11mm Phillips #2 screws holding the vacuum brushes in place.
Remove the brush module by pulling up from the sides.
Unscrew the 7mm Phillips #2 screw holding the corner brush head in place.
Flip over the brush module to access the corner brush motor.
Unscrew the 15mm Phillips #0 screws holding the motor in place.
Carefully take the motor axle from its housing.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Disconnect the wire connecting the motor using tweezers to pull out the connector.
Wish there was a way to replace that plastic. Stripped on mine.
Hi!
Is it possible to change just the plastic part where the brush screws in?
They did a really dumb thing and made a metal screw go in a plastic thread so of course, the plastic thread finally gave in.
The brush spindle gets replaced as part of the motor assembly.
Now I just need to find a good part # for the motor assembly. I'm replacing mine because of the worn out plastic spindle too.
