This guide will instruct you how to replace a filter in the iRobot Roomba 960. Side-Brush should be replaced often with frequent use.
With the Flathead 2.5mm screwdriver remove the 7.9mm screw from the side-brush.
Pull the side-brush towards you.
Carefully remove the side-brush.
