This guide will show you how to replace the whole Cleaning Head in the Roomba 880, which houses the Debris Extractors. Let's do it!
Flip the Roomba over, wheel-side up.
Using a Phillips #1 screwdriver, loosen the four 15 mm screws illustrated. Two are located on the battery door, while two are on the bottom panel.
Remove the battery door, pulling straight up from the two indents above the screws.
Using a flat head screwdriver, loosen the screw on the top of the side brush.
Remove side brush.
Pull up on the bottom panel to remove.
Reach underneath the dust bin, press the bin removal button, and pull out.
Using a Phillips #1 screwdriver, remove the four 10 mm screws shown.
Remove the cleaning head by grabbing the two protruding tabs as shown, and pulling straight up.
ブラシについては?どれが該当しますか?
ありがとうございました。解約手続きお願いいたします。
