This guide will provide instructions to replace the side brush that directs debris and contaminants towards the debris extractor to be picked up.
Start by locating the yellow side brush on the underside of the iRobot Roomba 860 near the front of the device.
Using a Philips #2 Point Screwdriver, remove the screw located in the center of the brush.
Pull up on the side brush and it should slide off, free of the motor shaft.
Remove any debris that could be preventing the side brush from spinning and/or replace the side brush.
What to do if the screw head is broken off? Thanks
