This guide will go over how to replace the battery in your iRobot Roomba 805. If you plan on putting in a new battery, you can order one from iRobot.
Unscrew the two captive Phillips #0 screws on the battery panel.
From the front of the panel (where there is an indent) pull the battery panel up and off the bottom of the Roomba.
Grab the battery by the straps on both sides and pull up to remove it from the Roomba.
