iRobot Roomba 650 Side Brush and Bottom Panel Replacement
  1. iRobot Roomba 650 Side Brush and Bottom Panel Replacement, Removing the Side Brush: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iRobot Roomba 650 Side Brush and Bottom Panel Replacement, Removing the Side Brush: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
    • Set the screw aside and pull the brush out.
  2. iRobot Roomba 650 Side Brush and Bottom Panel Replacement, Bottom Panel Removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iRobot Roomba 650 Side Brush and Bottom Panel Replacement, Bottom Panel Removal: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
    • The screws will not come out of the bottom panel. They were designed to become loose but not be removed. This prevents you from losing them, and prevents the Roomba from sucking them up if they came out during cleaning.
    • Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
crwdns2935229:05crwdne2935229:0
Charles Ward
crwdns2935283:001/22/15crwdne2935283:0
1.026 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 19-7, Maness Winter 2015 crwdns2935289:0Cal Poly, Team 19-7, Maness Winter 2015crwdne2935289:0
CPSU-MANESS-W15S19G7
crwdns2942667:0crwdne2942667:0 4,776
