iRobot Roomba 650 Main Wheel Replacement
  1. iRobot Roomba 650 Main Wheel Replacement, Removing the Side Brush: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iRobot Roomba 650 Main Wheel Replacement, Removing the Side Brush: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
    • Set the screw aside and pull the brush out.
  2. iRobot Roomba 650 Main Wheel Replacement, Bottom Panel Removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iRobot Roomba 650 Main Wheel Replacement, Bottom Panel Removal: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
    • The screws will not come out of the bottom panel. They were designed to become loose but not be removed. This prevents you from losing them, and prevents the Roomba from sucking them up if they came out during cleaning.
    • Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
  3. iRobot Roomba 650 Main Wheel Replacement, Main Wheels: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iRobot Roomba 650 Main Wheel Replacement, Main Wheels: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the six 12mm screws holding the side wheels on using a Phillips 00 screwdriver. There should be 3 on each side.
    • The screws do not come all the way out.
    • Remove the wheels by pulling them out.
Alex Schnorr
crwdns2935283:001/22/15crwdne2935283:0
649 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 19-7, Maness Winter 2015 crwdns2935289:0Cal Poly, Team 19-7, Maness Winter 2015crwdne2935289:0
CPSU-MANESS-W15S19G7
crwdns2936753:030crwdne2936753:0 51
crwdns2942667:0crwdne2942667:0 4,840
