If your Roomba stops picking things up the bin may be full and needs to be cleaned or a part of the bin may be broken and the bin needs to be replaced. If it is neither of those your filter may need to be replaced. This guide will show you how to do so.
Push the bin button and pull the bin out
Press the tab and pull open to access the contents of the bin.
Dump the contents of the bin out.
Pull on the 2 yellow tabs to slide the filter out.
Remove the filter.
