This guide is useful for replacing a dead battery or a battery that cannot be recharged through the dock for some reason. This guide is pretty simple can be done in 3 steps, and won't break anything important
Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
Gently pull the brush up and remove it from the device.
Unscrew the four 10mm screws on the underside of the Roomba using a Phillips #1 screwdriver.
Remove the bottom frame of the device.
Grab the green tape attached to the end of the battery and remove the battery from the device.
crwdns2935229:05crwdne2935229:0
Pls, can i charge the roomba directly, because the base is not working??
Yes I think so, mine can
Je dois chznger ma batterie qui est hs, mais les vis st morts, comment faire pour démonter le cache sans rien casser... sinon est ce que le cache et les vis peuvent être refournis par le sav?
