This guide explains how to remove the side brush motor from your Roomba.
Place your Roomba upside-down on a hard surface.
While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
Gently pull upwards on the brush to remove it.
Rotate the Roomba upside-down so the bottom is facing towards you.
Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
Use a Phillips #1 screwdriver to remove the two captive mounting screws on the side wheel motor assembly.
Gently pull on motor assembly to remove.
