iRobot Roomba 551 Battery Replacement
  1. iRobot Roomba 551  Battery Replacement, Side Brush: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place your Roomba upside-down on a hard surface.
    If all you need off is the faceplate, skip all of the screwdriver-based steps, and just remove the dirt bin(step 7) and start from step 11 at the rear.
    David Forrest - crwdns2934203:0crwdne2934203:0
  2. iRobot Roomba 551  Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. iRobot Roomba 551  Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull upwards on the brush to remove it.
  4. iRobot Roomba 551  Battery Replacement, Bottom Plate: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. iRobot Roomba 551  Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iRobot Roomba 551  Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. iRobot Roomba 551  Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. iRobot Roomba 551  Battery Replacement, Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iRobot Roomba 551  Battery Replacement, Battery: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the old battery by pulling the tabs on both sides.
    • Gently replace with a new battery.
Deborah Newberry
crwdns2935283:001/23/14crwdne2935283:0
623 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-14, Regan Winter 2014 crwdns2935289:0Cal Poly, Team 13-14, Regan Winter 2014crwdne2935289:0
CPSU-REGAN-W14S13G14
crwdns2935297:019crwdne2935297:0
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 11,013
