iRobot Roomba 4160 Spinning Edge Brush Replacement
  1. iRobot Roomba 4160 Spinning Edge Brush Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the Roomba is turned off to avoid an electric shock.
    • Turn the Roomba upside down, and place it so that the underside is exposed. The wheels and brushes should be visible.
    • Do not attempt to open up the yellow battery pack. You may get shocked or burned by the battery acid.
  2. iRobot Roomba 4160 Spinning Edge Brush Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iRobot Roomba 4160 Spinning Edge Brush Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Identify the yellow plastic rectangular battery, directly to the right of the spinning brush.
    • Place your index fingers on the small rectangular plastic tabs on both sides of the battery. Push the tabs in until the battery comes loose.
    • Pull battery out using your fingers.
  3. iRobot Roomba 4160 Spinning Edge Brush Replacement, Spinning Edge Brush: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iRobot Roomba 4160 Spinning Edge Brush Replacement, Spinning Edge Brush: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the spinning brush that is directly to the left of the rectangular pocket for the battery pack.
    • Unscrew the 7.2mm Phillips #1 screw from the spinning brush.
  4. iRobot Roomba 4160 Spinning Edge Brush Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the spinning brush upwards to remove it.
Garrett Rasmussen
crwdns2935283:004/07/14crwdne2935283:0
225 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-4, Forte Spring 2014 crwdns2935289:0Cal Poly, Team 6-4, Forte Spring 2014crwdne2935289:0
CPSU-FORTE-S14S6G4
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 411
