iRobot Roomba 4100 Flexible Rubber Brush Replacement
  1. iRobot Roomba 4100 Flexible Rubber Brush Replacement, Brush Guard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the Roomba upside down on a flat surface with the blue strip away from you.
  2. iRobot Roomba 4100 Flexible Rubber Brush Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iRobot Roomba 4100 Flexible Rubber Brush Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your index fingers to pull the yellow tabs towards you.
    • While still pulling the yellow tabs with your index fingers, tilt up the brush guard.
    • For reassembly, make sure to push in the brush guard until it clicks into place.
  3. iRobot Roomba 4100 Flexible Rubber Brush Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull back the brush guard to unhook it from the latches.
    • Remove the brush guard by lifting it up and out of the Roomba.
    • This picture has a change in orientation to illustrate the latches. Continue disassembling the Roomba with the blue strip away from you.
  4. iRobot Roomba 4100 Flexible Rubber Brush Replacement, Flexible Rubber Brush: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Set the brush guard aside.
    • The flexible rubber brush is the smooth, all-rubber brush that is closest to the yellow battery.
  5. iRobot Roomba 4100 Flexible Rubber Brush Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iRobot Roomba 4100 Flexible Rubber Brush Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the flexible rubber brush by grabbing it and pulling it up and out of the Roomba.
    • For reassembly, orient the Roomba with the battery closest to you:
    • First, insert the black end of the flexible rubber brush into the black square opening on the right side.
    • Second, lay the flexible rubber brush back into place.
Samantha Barrett
crwdns2935283:001/13/14crwdne2935283:0
501 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 17-5, Forte Winter 2014 crwdns2935289:0Cal Poly, Team 17-5, Forte Winter 2014crwdne2935289:0
CPSU-FORTE-W14S17G5
crwdns2942667:0crwdne2942667:0 987
