If your iRobot Mint is having trouble moving, this guide will show you how to take it apart and get it going again.
Remove the 4mm flathead screw on the battery cover.
Pull out the battery and unplug the wires.
Eight Phillips screws are located underneath the stickers.
Carefully cut around the 8 screw holes using an X-acto knife or razor blade to reveal the screws.
Remove the screws with a #2 Phillips screwdriver.
Separate wheel motor lid and set aside.
Remove four #2 Phillips screws.
With the device upside down, pull up to separate the bottom from the top cover.
Locate the three arrows on each wheel.
Insert metal spudger at arrow locations to pop off the wheel covers.
Use blunt nose pliers to remove circlip.
Once clip is removed you can pull the wheel off in an outward motion.
Remove two #1 Phillips screws.
Pull off sprocket.
Remove four #2 Phillips and lift off retainer.
Pull out all weights and set aside
Using the blunt nose pliers, peel up the adhesive and feed the wires with adhesive through the opening.
Flip the unit over and pull the motor out.
Nice! Very helpful.
Popping the wheel covers as shown breaks the small hooks that hold the wheel cover on. You need to rotate the cover clock wise to release them. There probably is a special tool that uses the small impressions in the cover.
