iRobot Braava 375t Motherboard Replacement
  1. iRobot Braava 375t Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iRobot Braava 375t Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip device over.
    • Remove the cleaning cloth compartment on the bottom to access screws.
  2. iRobot Braava 375t Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the four bottom cover screws.
    what's the size of the Philips screwdriver.
    Chris Yepez - crwdns2934203:0crwdne2934203:0
    I mean like is it 1.6mm, the size of it
  3. iRobot Braava 375t Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device back over and remove the shell by unplugging the wire that is holding the shell to the motherboard.
  4. iRobot Braava 375t Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the rest of the wires and remove all screws that are attached to the motherboard.
    • To remove the wires, disconnect the plastic pins in a similar fashion to the ones in the Battery Replacement guide.
  5. iRobot Braava 375t Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the zip ties holding the wires together using a sharp object or thin scissors.
    • If you do not have pliers or a wire cutter available, then you can use the heads of thin screwdrivers to wedge the zip ties enough to remove them.
    The circles make it much easier to know what needs to be done
Angel Ledezma
crwdns2935283:009/26/22crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 5-5, Adachi Fall 2022 crwdns2935289:0CSU Los Angeles, Team 5-5, Adachi Fall 2022crwdne2935289:0
CSULA-ADACHI-F22S5G5
crwdns2931471:06crwdne2931471:0
How long does this guide take?
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 198
