iRobot Braava 375t Battery Replacement
  1. iRobot Braava 375t Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device over upside down and locate the battery panel.
    • The panel has a symbol of a trash can crossed out.
  2. iRobot Braava 375t Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After locating the panel, locate the screw (should be around the top center).
    • You will need a medium sized flathead screwdriver to loosen the screw.
  3. iRobot Braava 375t Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the screwdriver and turn counter clockwise (left) to loosen the screw.
    • You may need to apply pressure when turning if the screw is tight.
  4. iRobot Braava 375t Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iRobot Braava 375t Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the screw is completely taken off, remove the panel to reveal the battery.
    • The battery will have a wire, follow the wire which will lead to a plastic white clip (pin). Pull the wire clip upwards carefully until the all pins are separated.
    • Use a small screwdriver and wedge the head between the clips if the pins are tight.
Jadealyn Paulino
crwdns2935283:009/26/22crwdne2935283:0
275 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 5-5, Adachi Fall 2022 crwdns2935289:0CSU Los Angeles, Team 5-5, Adachi Fall 2022crwdne2935289:0
CSULA-ADACHI-F22S5G5
crwdns2931471:06crwdne2931471:0
crwdns2942667:0crwdne2942667:0 265
