Without properly functioning wheels, the Braava will have a difficult time navigating. This will lead to inefficient sweeping or mopping. This guide will show how to replace the Braava's wheels.
Flip your device over and locate the battery cover.
Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
Gently remove the battery from the tray and disconnect the battery cable.
To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
With the battery removed, rotate your device so the front of it is facing you.
Remove the four 10mm Phillips #2 screws that attach the shell.
Using both hands, hold the device together while you flip it over.
Starting from the front, gently lift up the shell and slowly tilt back until it is fully removed.
FYI, the shell on my Braava 380 had a cable that connected it to the base that needed to be disconnected before the shell could be fully removed.
To remove the wheel covers, hold the wheel in place with one hand while turning the cover clock-wise with the other.
I couldn’t get the wheel cover to come off. :-( Fortunately, my wheel wasn’t broken, I’d just been hoping to clean the axels. I put it all back together, and just cleaned the axels next to the wheels as best I could.
I couldn’t get the wheel cover off my Braava 380 and so I got stuck here. :-( Fortunately I didn’t have a broken wheel - I just wanted to get at the axels to clean them. So I put it all back together and pulled out the hair and dirt stuck in there with the wheel on.
Yeah… the wheel cover was a monumental pain in the butt to remove. I had to drill two small holes to fit a spanner wrench into to make it happen. And when I replaced the old wheels with new ones, I couldn’t get to click back into place so it’s on there but it’s seatbelt ain’t on.
Using a small Flathead screwdriver, remove the small black clip in the center of the wheel.
I accidentally lost the black clip during try to remove hair that tighten around the wheel. Did not mean to replace the wheel yet
Once the small black clip is removed, the wheel should come off by gently pulling on it.
crwdns2935229:013crwdne2935229:0
O roteiro descritivo para a troca das rodas do Braava foi muito útil. Obrigada!
