The battery is an essential component to the iRobot Braava 320. Without a functioning battery, your iRobot could have trouble turning on, staying on, or charging. Replacing the battery may solve these issues.
Flip your device over and locate the battery cover.
Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
Gently remove the battery from the tray and disconnect the battery cable.
To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
where do I get a new battery from?
