iRULU AX106 Speaker Replacement
  1. iRULU AX106 Speaker Replacement, iRULU AX106: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Philips head #00 screwdriver locate and remove each of the four screws located along the tall side of the iRulu.
    • There may be plastic covers protecting the screws, if this is the case take a phillips head screwdriver, and gently apply pressure on the covers until they come off.
  2. iRULU AX106 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iRULU AX106 Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the opening tool to pry the screen from the case applying pressure at each of the four corners of the screen.
    • While a good deal of force is required to separate the screen from the case, make sure to separate the screen from the case at each corner before attempting to completely remove the screen. There are delicate wires that may be damaged if the screen is removed is before the corners are separated.
  3. iRULU AX106 Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iRULU AX106 Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iRULU AX106 Speaker Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  4. iRULU AX106 Speaker Replacement, Speaker: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Desoldering Pump
    $3.99
    • Locate the two speakers and using the soldering iron and solder sucker carefully remove the solder that binds the two speakers down.
    • Insert the new speaker heads where the old speakers were previously.
    • Now use the soldering iron to solder the leads of the two speakers onto the logic board.
    • Be careful, the soldering iron will be extremely hot.
Andrew Mele
crwdns2935283:003/24/15crwdne2935283:0
146 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-7, Vijaybhaskar Spring 2015 crwdns2935289:0UMass Dartmouth, Team 4-7, Vijaybhaskar Spring 2015crwdne2935289:0
UMASSD-VIJAYBHASKAR-S15S4G7
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 435
