我们在2008年9月10日拆解了这部iPod。
新的iPod touch包装在一个更小的、透明的塑料盒子里。
有人问我们拆机何不把它开机看看新的软件。我们只是……等不及。
盒子里还有:
耳机
USB 2.0线缆
Dock适配器
清洁布
My IPT did not come with a polishing cloth doese every IPT come with one?
正如所料,外形更新得和iPhone 3G别致的曲线一致。
卸下玻璃与触摸屏总成。
Guys, for anyone trying to dissemble their ipor, be very carefull, there is on the top left of the ipod behind the benzel, a very thin cable that connects the benzel to the mother board. If you trying to remove the benzel, do not lift it untill you got the tape out, then carefully lift the benzel, and unplug the cable.
Hey, this is not easy... I've successfully broken the LCD on my ipt2g trying to fix a chip in the glass. the mistake occurred when i was initially popping it open. Ive spent the last two years of my life fixing cellphones for a radio shack and like to consider myself somewhat of an expert on using a pry tool to pop open anything. i made a noob mistake. the kind of simple ^@^^ i did on my first phones. this is simply not easy to do, applying to much force causes a violent opening, not enough and you fidget around until you slip up. go at it with purpose and a good mindset. hold it above something soft and never allow you hands to get sweaty. when you slip and break it, try to keep your cool and not kick a hole in drywall.
xKOMx... yo
U R so right, this is no experience for the faint of heart, I use 3 guitar picks, have been modified, used to use the Nokia tool (I'm Nokia level III certified) stil, I've manage to open 3 of this iPods.
GOOODDD, it's so difficult, please, be very careful, you'll find yourself replacing in the best case scenario the Digitizer.
Good luck
Beware of cracking glass opps!
What wisth is the spudger? Where can one have one?
For some reason the multi-touch stopped working after i started to remove the glass. should i pretend that i didn't try and mess with it and send it in for warranty repair or should i try again to take it apart? i don't know why it isn't working whether i nicked something or if somehow the glass isn't touching anymore or something silly like that.
I've also cracked my sceen trying to get it open. :(
Cool. I cracked my bezel too. Why aren't there any written instructions or warnings? $65 mistake. Ugh…
crwdns2936937:0bizzbobbcrwdne2936937:0
Actually, this warning is written across the top of the page:
"Teardowns provide a look inside a device and should not be used as disassembly instructions."
What if you cracked your glass display cover can you fix it and how do you know if you cracked you LCD also?
i crack the LCD screen nd the bottom(down) sensors wont feel when i touch it above(top) does feel when i touch it, idk what do to lol
crwdns2936937:0Floofycrwdne2936937:0
did you figure out what you did...either i have done something different or similar!
I luv this website but man what a bad set of instructions for #4. I have been repairing iPhone's for some time now and just tried my first iPod touch using these instructions....not only did I destroy the digitizer, I also destroyed the frame and the lcd! then I went to youtube and for the correct instructions. Im not blaming iFixit but a complete set of instructions would be very helpful!! oh and i still luv this site and I luv the tools I just bought off here!
crwdns2936937:0chargitcrwdne2936937:0
I dont understand it took me less than 45 mins to replace the digitizer and bezel and the contact was easy to connect btw i got the bezel and digitizer under $30 so look for a good seller!
Does anyone have any tips for removing the glass... I cracked mine... badly... using the same techniques...
really? 10 years and nothing? RIP now cracked the glass…
露出来的LCD显示屏。
苹果给出的屏幕数据是:3.5英寸合8.89厘米(对角线),分辨率480×320像素,163ppi。
What is the function of the copper adhesive tape at the top of the LCd screen
crwdns2936937:0tonycrwdne2936937:0
ground connection for the LCD, protects from static, etc, may also hold down something underneath!
没有用螺丝固定LCD,而是用一小片双面胶。
There are 6 screws connecting the metal baking to the back plate
wow #*#! u guys i broke the glass
取走金属背面。
电池用两条轻质胶粘剂粘着,但很容易剥离。
how do i remove the metal backing to remove the battery? do i need to buy one of your screwdrivers?
断开显示数据排线。
可看到用于把电池黏到金属背板的胶水的残余。
越来越令人激动了!
形状颇大的橙色线缆连接WiFi天线(左上角)与主板。
图片顶部电池之上是一个金属罩。罩子之下是高通的BCM4325 WiFi及蓝牙芯片。没错,蓝牙!苹果对此没有任何公开说明。
这款蓝牙芯片组支持蓝牙2.1+EDR。还不知道苹果用的支不支持A2DP这项可连接立体声耳机的协议。
部件编号:BCM4325GKWBG CD0825 B76332 P40 SF
Very interesting about the Broadcom chip. I wonder why Apple shut that functionality down? I mean, if it has bluetooth I could hookup a headset and use Fring with no problem.
The bluetooth could be a way of tracking people or something i think someone is controlling my IPT because it will close out to the home screen in the middle of a game and that makes me mad anybody know why it does that and if it can be fixed?
crwdns2936937:0Qmancrwdne2936937:0
That is because Ram inside the device is getting so hot that it is nearly going to overheat so the ipod cleverly shuts down the application so it can free up RAM.
crwdns2936937:0technobotcrwdne2936937:0
an add: restart the device to really clear the RAM.
I'm having freezing trouble while playing music using the external speaker. When it happens the left bottom of the iPod becomes really hot. It's in the region of that chip of step 13 with the white sticker. Do you know what is that?
That is because Ram inside the device is getting so hot that it is nearly going to overheat so the iPod cleverly shuts down the application so it can free up RAM.
Its not because the ram is overheating, the device doesnt generate enough heat for that to even be a factor, its because the ram is getting full.
Nothing about the RAM getting hot. It's just running low on memory. Apps start closing when the device has about less than 10 MB RAM available. But jailbreaking solves this, there are tweaks that allow for expanding virtual memory, e.g. iMemory Enhancer from Gumball Tech repo.
你可以看到中间的dock连接座和右边的耳机孔。
Do you have to dissasemble the whole board just to get to the earphone jack? I need to replace it... it looks like it requires soldering?
crwdns2936937:0pteotexzcrwdne2936937:0
I have the same question.
hal
Did anyone resoldered this? Is it difficult?
主板。
我们认为中心的棕色长方形是扬声器。看上去它右边的橙色线缆连接到新的音量控制键上。
电池。和料想当中一样,是3.7V锂离子聚合物电池。编号是616-0404。还不知道额定多少毫安时。
还是主板,不过我们把我们所认为是扬声器的东西移开了。
闪存是一颗镁光MLC芯片:MT29F64G08TAAWP
处理器是带有苹果标识的三星制ARM,和SDRAM封装在一起,如同iPhone的那样。
结束。
Where does one purchase a replacement back panel?
Thanks! Broke mine down too, except i used a flat screwdriver and a pocketknife! :)
not as clean as your teardown, but quite the same. Great job!
Where might one purchase a new back plate?
crwdns2934873:0crwdne2934873:0
94%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Broke the screen.
probaly should of used a hair dryer
i need all the parts of ipod touch 2nd generation
hard to do really
