Replacing the battery requires a fine-tipped soldering iron.
Before proceeding, be sure your Shuffle is switched off.
Use a combination of iPod opening tools and metal spudgers to pry the rear panel away from the Shuffle by the seam nearest the ON/OFF switch.
Remove the rear panel from the Shuffle.
Remove the single 2.1 mm Phillips screw securing the logic board to the front case.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use the edge of an iPod opening tool to flip up the retaining flap on the control button cable ZIF socket.
Use a pair of tweezers to gently pull the control button ribbon cable out of its socket.
Use an iPod opening tool to gently pry the battery off the adhesive securing it to the front case.
Lift the battery out of the front case, being sure not to strain its delicate leads.
Insert the tip of a metal probe into the hole molded into the logic board retainer nearest the logic board.
Pry the retainer first away from the front of the front case, then pull it away from the side of the front case.
Remove the logic board retainer from the Shuffle.
Use the edge of an iPod opening tool to push the headphone jack down toward the center of the Shuffle.
Continue pushing the logic board down away from the top edge of the Shuffle.
Pull the logic board out of the front case by the side nearest the ON/OFF button and gently maneuver the headphone jack out of its recess in the front case.
Remove the logic board assembly from the Shuffle.
Use a tip of a sharp metal probe to scrape off the glue covering the battery terminals near the control button ZIF socket.
crwdns2935267:0crwdne2935267:0FixHub | Power Series Smart Soldering Iron$79.95
Use a fine-tipped soldering iron to heat up the battery connections boxed in red one at a time while you pull the corresponding lead away from the other side of the logic board.
crwdns2935229:054crwdne2935229:0
crwdns2947412:024crwdne2947412:0
I have a question. Why can't the leads to the old battery be cut without pulling the board, then just solder new battery leads to the old. Seems it might even be possible to add snap in connectors at this point to facilitate future changes.
i have the same q.
imhockey -
Sure that’s a good plan also. Just make sure not to short the wires in any way and detach the negative wire first on disconnect & negative last on connecting again.
For a connector you’ll really need a very small connection then cause the space is very limited inside.
Ha ns -
I'm gonna try to remove the back cover with minimal prying to reduce cosmetic defects. The plan is to somehow remove the spring loaded clip by pushing out the lever pin, then drilling holes along the edge of the over wherre the 3 little hooks are (In this image, where the right thumb is touching. https://d3nevzfk7ii3be.cloudfront.net/ig...).
It would be great if someone could provide a closer look at where exactly the hooks are so I can position my 1.5mm drill bit better. Also, if you can to figure out how to remove the spring loaded clip mechanism without going through the 4 screws, that'd be awesome! I suspect the pin is held in place by just adhesive, but don't want to risk pushing too hard and causing defects. :(
Check my comment in the article on that specific step. You don’t have to drill out anything. You can use the clip on the shuffle itself to slightly force the back plate to bend giving enough room for the clips to snap off.
Ha ns -
