crwdns2959928:0crwdne2959928:0 ↓Your iPod's motherboard controls just about everything on the iPod.
crwdns2935267:0crwdne2935267:0Jimmy$7.95
Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
To make this job easier, heat up the adhesive with a hairdryer on low heat for a few seconds.
Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic bottom Use the screwdriver to pry up the white plastic bottom bezel. Be careful not to damage the soft plastic with your screwdriver.
A small pair of snap ring pliers is the easiest tool to remove the metal retaining bracket.
You can also use a flathead screwdriver to pry out the metal retaining bracket beneath the bottom bezel as shown. You can free the bracket by first pushing in the metal arms on the corners and then lifting the bracket.
Lift the metal retaining bracket out of the iPod.
Use a spudger or the tip of your finger to carefully disconect the orange click wheel ribbon from the logic board.
Remove the two #00 Phillips screws securing the headphone jack to the casing.
Carefully slide the iPod out of its casing by pushing on the logic board near the bottom edge of the click wheel.
After pushing the logic board out sufficiently, gently grasp the logic board on either side of the display, and continue to slide the iPod out of its casing.
Lift the battery off of the logic board and lay it to the side of the iPod.
Use a spudger to flip up the black plastic tab holding the orange display ribbon in place. The black tab will rotate up 90 degrees, releasing the ribbon cable.
Note the location of the four white plastic tabs securing the display to the logic board. These tabs must be released before the display can be removed.
Use a spudger or your finger to free the four white plastic tabs indicated in the previous picture.
Turn the iPod over.
Carefully lift the display up and slide it out of its connector.
Use a spudger to carefully pry up the headphone jack board from the logic board. Be careful to pry up near the connector to prevent unnecessary strain on the board.
Carefully disconnect the battery from the logic board. Make sure to pull only on the connector and not on the battery wires.
Use a spudger or the tip of your finger to carefully disconect the orange hard drive ribbon from the logic board.
Lift the hard drive out of the iPod.
crwdns2935229:020crwdne2935229:0
Can You give me a step by step process for reassembling an iPod mini after replacing the logic board. I cannot follow the steps in reverse to reassemble it. Also, is there a youtube video showing the reassambly?
ahmartensson49 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
