crwdns2959928:0crwdne2959928:0 ↓The colored metal casing.
Spudger4.9
crwdns2935267:0crwdne2935267:0Jimmy$7.95
Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
To make this job easier, heat up the adhesive with a hairdryer on low heat for a few seconds.
Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic bottom Use the screwdriver to pry up the white plastic bottom bezel. Be careful not to damage the soft plastic with your screwdriver.
A small pair of snap ring pliers is the easiest tool to remove the metal retaining bracket.
You can also use a flathead screwdriver to pry out the metal retaining bracket beneath the bottom bezel as shown. You can free the bracket by first pushing in the metal arms on the corners and then lifting the bracket.
Lift the metal retaining bracket out of the iPod.
Use a spudger or the tip of your finger to carefully disconect the orange click wheel ribbon from the logic board.
Remove the two #00 Phillips screws securing the headphone jack to the casing.
Carefully slide the iPod out of its casing by pushing on the logic board near the bottom edge of the click wheel.
After pushing the logic board out sufficiently, gently grasp the logic board on either side of the display, and continue to slide the iPod out of its casing.
Use a spudger to pull back on the small black plastic tab holding the click wheel in place.
Continue to pull back on the black plastic tab and use your other hand to press down on the click wheel and begin to slide it out of the iPod.
Continue to slide the click wheel out until it is free of the iPod.
crwdns2935229:024crwdne2935229:0
Followed your instructions to the letter. Put it back together and now it won't work . Thanks for breaking my iPod mini.
kolbyhardy - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
You probably &&^&@@ something up by mistake. Don’t blame the author for your own mistakes.
Crystal Haugh - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
dude the pod mini is an mp3 player from 2005 it literally does not matter, plus, you probably &&^&@@ up the repair anyways
Memez_idk - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
@kolbyhardy He didn't touch your ipod mini. Anything you did to it is YOUR fault, not anyone else's, own your mistakes.
Cactus12 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
