Over time, old iPods with hard drives can experience common errors like a dead battery or an unresponsive hard drive. In this tutorial we will replace an old hard drive of an iPod 4G with a micro sd card of potentially greater capacity. (The screen shown in this tutorial is a sign of a failing hard drive)
Insert an opening pick as far as possible into the seam between the plastic front and the metal rear panel, on the right edge of the iPod.
Use the opening pick to pry up against the plastic front panel and release five retaining tabs (seen in the third photo).
Slide the pick along the edge of the iPod and continue prying to release the rest of the retaining tabs.
After all five tabs along the right side are free, the case should easily open.
Open the case like a book with the dock connector edge at the top, and lay the rear panel next to the front half of the iPod.
Use a plastic tool or your fingernails to carefully disconnect the orange headphone jack cable. Be sure to pull straight up on the connector, not the cable itself.
Remove the hard drive with your hand, by holding both the iPod and hard drive connector (hold tight in order to not broke the connector).
Put the micro sd card into the CF adapter.
Then put the CF adapter into the CE to CF 1.8" adapter.
Depending on the CE adapter you have, you may need to remove the stopper on the hard drive disk connector on the iPod. Use tweezers to do so.
Plug your memory unit in place of the old hard drive.
It's normal that to have 4 free slots on the memory unit. Be sure to position the memory unit as on the photo.
Reconnect the bottom case connector. Before reassembling the iPod.
Just put the top case on the bottom one without pushing.
After connecting the iPod to the PC you may need to install iPod support. Follow iTunes instructions. Unplug the iPod, Restart iTunes, Restart your PC. Replug the iPod.
Once connected to your computer, iTunes will tell you that the iPod needs to be restored. Follow iTunes instructions to restore the software.
The iPod will prompt you to plug it to a wall plug. While this screen is displayed you can't continue.
If it reboots to the iPod menu (language settings) you have finished.
Finalize the software restoration process by accepting the Apple license.
It's important that you check everything, from charging to synchronizing and listenning to music before reassembling the iPod.
If something is not functionning properly, double check each steps.
To reassamble your iPod follow the steps in reverse order.
crwdns2935229:05crwdne2935229:0
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
