iPhone 8 Back Glass Replacement
crwdns2936621:0crwdne2936621:0
  1. iPhone 8 Back Glass Replacement, iPhone 8 Back Glass Replacement: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wire up the Back Glass Separator. Connect the Back Glass Separator with Air Compressor via an air pipe. Switch on the Air Compressor. Open the air compressor valve.
    • Switch on the Back Glass Separator. Rotate the pressure regulating valve and set the value as 0.4Mpa.
    unless you are planning to replace multiple Back Glasses, purchasing a tool like this is not an interesting solution. The entire housing can be picked up for about 30$ with usb elements present ... although you will have a 4 to 5 hour job putting everything back together.
    Bill McNamara - crwdns2934203:0crwdne2934203:0
  2. iPhone 8 Back Glass Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 8 Back Glass Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place iPhone 8 back glass assembly into the corresponding mold. Press ‘Up’. With the temperature rising to 240℃, press ‘Start’. The back glass assembly is clamped tightly by the mold.
    • After 200 seconds of heating, mandril of the machine starts to work.
  3. iPhone 8 Back Glass Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back glass after 18 seconds. Remove glue residue on the back glass thoroughly.
    • iPhone 8 back glass separating has been completed successfully.
    • Attach a new back glass to the midframe in the end.
crwdns2935229:014crwdne2935229:0
Phryne
crwdns2935283:011/17/19crwdne2935283:0
21.137 crwdns2915208:0crwdne2915208:0
crwdns2935297:018crwdne2935297:0
Where does it show the replacement I only see the removal?
ManDeen - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 63
crwdns2936753:030crwdne2936753:0 278
crwdns2942667:0crwdne2942667:0 56,977
