crwdns2931315:0crwdnd2931315:0crwdne2931315:0
crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Use the point of a spudger to lift and disconnect the antenna cable from the bottom end of the logic board.
Use the point of a spudger to lift up and disconnect the Lightning connector ribbon cable from its socket on the logic board.
Use the point of a spudger to lift and disconnect the antenna cable from its socket near the top of the logic board.
Carefully lift the antenna cable and de-route it from the edge of the phone. Use the point of a spudger to help lift the cable to free it from the retaining clips.
Remove the following Phillips screws securing the speaker to the rear case:
Two 2.6 mm screws
One 2.3 mm screw
One 2.3 mm screw
One 3.0 mm screw
Insert the flat end of a spudger between the long edge of the speaker module and the case wall.
Pry gently to loosen the speaker module.
Once the module is loose, lift and remove the speaker module from the phone.
