iPhone 6s Plus Speaker Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. iPhone 6s Plus Speaker Replacement, Speaker: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 6s Plus Speaker Replacement, Speaker: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the antenna cable from the bottom of the logic board.
  2. iPhone 6s Plus Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 6s Plus Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the Lightning connector cable from the logic board.
  3. iPhone 6s Plus Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 6s Plus Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three Phillips screws securing the Lightning connector bracket:
    • Two 3.5 mm screws
    • One 2.7 mm screw
    • Remove the bracket.
  4. iPhone 6s Plus Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 6s Plus Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the antenna cable from the Lightning connector assembly.
  5. iPhone 6s Plus Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 6s Plus Speaker Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the antenna cable from the top of the logic board.
  6. iPhone 6s Plus Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 6s Plus Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 6s Plus Speaker Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully lift the antenna cable and de-route it from the edge of the phone. Use the point of a spudger to help lift the cable free it from the retaining clips.
    • If the cable does not have enough room to lift up, loosen this Phillips screw securing the logic board so that the board can give more wiggle room.
    • Be sure to re-tighten this screw during re-installation.
    • If the cable snags near the SIM reader, it's likely caught on the SIM tray ejection mechanism. Use the point of a spudger to slide the plastic rod out of the way.
    • During re-installation, be sure to route the antenna cable underneath the logic board corner.
    • During reassembly, you can also re-insert the SIM card tray after re-routing the antenna cable.
    • If you feel any resistance, stop and make sure that the tray isn't snagging the antenna cable.
  7. iPhone 6s Plus Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 6s Plus Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six Phillips screws securing the speaker to the rear case:
    • One 2.5 mm screw
    • Two 2.7 mm screws
    • One 1.5 mm screw
    • One 1.7 mm screw
    • One 2.6 mm screw securing the speaker to the bottom edge of the rear case.
  8. iPhone 6s Plus Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 6s Plus Speaker Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 6s Plus Speaker Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger between the long edge of the speaker module and the case wall.
    • Pry gently to loosen the speaker module.
    • Once the module is loose, lift and remove the speaker module and the attached antenna cable from the phone.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
298,865 crwdns2915208:0crwdne2915208:0
crwdns2935297:0684crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,981crwdne2935297:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 199
