iPhone 6s Battery Connection
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. iPhone 6s Battery Connection, Battery Connection: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm Pentalobe screws surrounding the Lightning connector.
  2. iPhone 6s Battery Connection: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    iSclack
    $24.99
    • If you don't have an iSclack, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
  3. iPhone 6s Battery Connection: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 6s Battery Connection: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 6s Battery Connection: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There is a notch on the underside of the display just above the headphone jack that is the safest place to begin prying the phone open.
    • Pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices and is held down with adhesive.
    • Once a small gap has been opened, insert the flat end of a spudger above the headphone jack.
  4. iPhone 6s Battery Connection: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 6s Battery Connection: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Twist the spudger to open the gap more and break it free from the adhesive.
    • Keep pulling up on the suction cup while twisting the spudger.
  5. iPhone 6s Battery Connection: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 6s Battery Connection: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the edge of a spudger to slice through the adhesive on either side of the phone.
  6. iPhone 6s Battery Connection: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 6s Battery Connection: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  7. iPhone 6s Battery Connection: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 6s Battery Connection: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 6s Battery Connection: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the suction cup to open the display, breaking the last of the adhesive.
    • Don't open the display more than 90 degrees, as it is still connected at the top by three cables that may break if stretched.
  8. iPhone 6s Battery Connection: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lean the display against something to keep it propped up while you're working on the phone.
    THESE INSTRUCTION / GUIDE IS NOT COMPLETE. I broke my phone and ended up with $250 in repairs at the local cell phone store at this step. You need to detach the display completely instead of prop it up against a box. It is very likely your cables will tear at this step if you don’t completely detach the display
    Christopher Kuhar - crwdns2934203:0crwdne2934203:0
  9. iPhone 6s Battery Connection: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following screws from the battery connector bracket:
    • One 3.0 mm Phillips #00 screw
    • One 2.3 mm Phillips #00 screw
  10. iPhone 6s Battery Connection: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the metal battery connector bracket from the iPhone.
  11. iPhone 6s Battery Connection: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 6s Battery Connection: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 6s Battery Connection: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to disconnect the battery connector from the logic board.
    • Push the connector to the side to ensure it doesn't accidentally make contact and power on the phone while you're working on it.
Sam Goldheart
crwdns2935283:010/18/12crwdne2935283:0
472,336 crwdns2915208:0crwdne2915208:0
crwdns2935297:0538crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020,083crwdne2935297:0
While replacing a charging port on the 6s I realized that the battery didn't seem to stay seated. It also won't charge past a certain percentage. Anyone run into this?
CellularRepairEtc - crwdns2934203:0crwdne2934203:0
BE FOREWARNED: I used this guide and ended up breaking one of the cables to my display on step 8. Now my home button, camera and speaker don’t work and I have to spend 80 dollars for a new lcd panel.
The featured guide (not this one) shows how to completely detach the screen cables so this won’t happen. Do a quick search and take a look before possibly breaking your phone on step 8. Fully detaching the panel would have prevented this issue
DO NOT USE THIS GUIDE: It is not complete. I ended up having to goto the store and pay $250 dollars to get my I phone fixed after breaking it with these incomplete directions.
This is a more complete guide use this one: iPhone 6s Battery Replacement
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 431
