Entferne die Rückabdeckung, damit du an die internen Komponenten deines iPhones herankommst.
Schalte dein iPhone aus, bevor du mit der Demontage beginnst.
Entferne die beiden 3,6 mm P2 Pentalobe Schrauben neben dem Dockanschluss.
Drücke das Rear Panel Richtung Oberkante des iPhones.
how can i take out the screw if it is stripped
with a small driller, but I guess it is very difficult. Never attempted that myself on an iPhone.
lantzero -
There is no screw in Step 2?
Is the screw stripped or the head stripped?
I have used superglue on the screwdriver to remove a stripped screw, it would turn but not come out, with superglue I could turn and pull the screw out. May also work on a stripped head.
Trevor -
If you are careful, use a Dremel tool and a micro drill bit (sold where Dremel tools are purchased) to drill it out. Last resort kind of thing, good luck.
Why isn't it moving? I removed my screws.
I didn't see any extra screws holding the back in place. I had to use the included pry tool to get the back off. Just start at the bottom and pry gently...if you just "pull" like the guide says it won't work.
Don't use too much force to slide the back -- the back on my phone was hard to slide, and I bent and broke a silver metal contact tab at the top of the back (on the inside).
Super easy fix. Thanks for the tutorial!
Those little screwdrivers are easy to mix up, for those of us without ultra-perfect vision! Once I used the correct screwdriver, and my 13yo son's little fingers and perfect eyes, it went smoothly! Also my son noticed that the rubber piece around the camera len was covering the camera; it likely slid out of place when sliding off the back cover. A little playing around (with plastic tools only!) and it looks perfect now!
sorry but the rear panel is not pushed up. I pulled out the screws in the step 1 but still the rear panel does not move with even when I push it strongly.
I too tried to push and slide the rear cover without success. I then tried just pushing the bottom edge up with my thumbnails. It moved very easily forward. Just a few mm movement is needed and then the cover can be removed.
The finger friction approach did not work for me, even when using a sticky pad.
Here is what worked for me: Grab the iPhone in your right hand with the screen facing your hand and the top facing your body. Find a sharp edge of a desk or counter and place the bottom of the phone's back cover on is so that when you push it, the back cover remans against the desk with the body of the phone sliding free. BE GENTLE as this approach takes far less force than the finger friction approach.
Zieh das Rear Panel von der Rückseite des iPhone weg und pass auf, dass die Kunststoff-Clips, die am Rear Panel befestigt sind, nicht beschädigt werden.
Entferne das Rear Panel vom iPhone.
On reassembly, be sure to clean the metal plate at the place of contact with the tiny pressure contact mentioned in step 4.
I pried one end of the back off only to find 2 funny little screws holding the other end on so I took my Dremel, like Jack said, and ground those suckers out. Once I had the back off I loosened all the screws then turned it upside down and shook the crap out of it. The screws went flying everywhere and fell on the floor. Its my moms house so of course she's got gross brown carpet. How am I supposed to find my screws in that? I get the vacuum out and go over every inch of the floor to suck up all them screws. Then I dump the bag on the table and all I find is a bunch of hair and gods knows what else, but no screws. When I look for my phone I see its covered in all that stuff that came out of the vacuum. I mean, what's up with that? How can I work on my phone if its covered in dirt? Nobody said anything about that, did they? The average guy's gonna screw up his phone big time if he follows these instructions and nobody warns him about all the dirt that's gonna end up in his phone. Are you kidding me!! Now what?
The replacement panel I got had two sheets of protective plastic on the inside and one on the outside. I used a toothpick to carefully lift and peel the two inside sheets off. One small one was over the lens on the inside. The other was over some large brown sheet of unknown function (though I think it goes over the battery). When I peel that away, some of the brown material tried to lift of with it, so be very careful.
From this point go to step ?? Just peel off the tape from the chip. Take some aluminium foil and cut a hole the size of the chip (Use a second layer of foil if you don't thrust it). Heat the chip as described at temperature 300 deg C for 5 minutes. Let it cool down. Reassemble and ..... hura WIFI is on again.
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
crwdns2935229:0808crwdne2935229:0
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
crwdns2944067:015crwdne2944067:0
If you have trouble removing the back after sliding it, do not force or pry it. You didn't push it far enough. Gently push it further and it will come off easily!
On the iPhone 4S Mirrored Rear Panel there was a clear plastic covering on the INSIDE side of the Panel that covers a jagged black area. There is also a small plastic covering over the camera lens, also on the inside side of the Panel. The iFixIt step-by-step instructions do not include any information about whether to remove these or leave them. I chose to peel them off and it appears everything works okay. But there probably should have been a mention about what to do with these "stickers."
Thanks! I didn't notice the scuff covers until we noticed the poor quality of the photos. After I took the back off and removed the film covers, the photos are back to the original quality. Thanks again for your comment. The covers should have an obvious tab on them for easy removal
www.partoflaptop.com/iphone-4s-repair-parts_iphone-4s-rear-panel-replacement.html
there are many kinds of iphone 4s rear panel from this site:
I had problems with the fit of the mirrored back . Some of the tabs on the new back did not align with the 4 S - so rather shipping back the part I tried to make it fit - cut of 3 of the tabs that did not align and then it fitted and works . It is slightly thicker than the old one and the external body-glove cover fit is a bit of a squeeze but make do .
Seems that some of these generic part are made for a few models ans do not exactly fit . Knowing this now I probably would have gone for the real apple back than the generic one . I would also have expected that ifixit should have mentioned it .
Now for the hard drive replacement in my Mac Mini - hope that one goes easier :-)
There is plastic covering the camera lens on the inside. After finding my pictures cloudy I removed the back and carefully removed the thin plastic covering. The pictures now look great again.
I have completely disassembled a iPhone 4S that was dropped in a puddle. So I am very familiar the phone. But today I tried to replace a cracked back with a iPhone 4S Revelation Kit. The original cracked back would slide on and off with no issues. In an effort to get the new back to fit in the phone I broke one of the screw tabs. I could never get the top of the back to fit flush with the phone. I am ordering a new one, but is there any trick to get the replacement back to fit? I ordered a 4S kit, but what i got was 4/4S kit. Is there any difference between the 4 and the 4S back?
I have the same problem. And when I tried to push the new panel get the top it just couldn't fit. Finally I succeeded but the glass panel was a bit broken, too. I think the problem should be that the middle bayonet because I found its round corner was a little bigger than the original one. I'm not sure if your problem have the same reason but I suggest you to check that round corner of the middle bayonet.
What does this mean Anyone?????????????????????????? The 5-Point Screwdriver should only be used once, as it has the potential to strip the screws.
Could not have been an easier repair. Total time 3 minutes.
Great product and super easy install. Took about two mins. Highly recommend. Thank you iFixit.
Two minutes. Seriously. Two. Dear effing dog, why didn't I do this 1-1/2 years ago?
I can’t get the replacement on! The original one slides on no problem…
I cannot charge my iphone 4s unless I turn it off while connected to charger. I can’t connect to iTunes either. Help
The Liberation Kit just stripped the screw. Now what.
nimpsy - crwdns2934203:0crwdne2934203:0
Had local iPhone repair shop remove the screw. Repair complete!
nimpsy -
I left the battery in and everything above the middle, using a pen knife to flex the logic board, I had plenty of room to else the old out and the new in.
Worked well and saved a lot of time.
Keith M - crwdns2934203:0crwdne2934203:0
After reviewing the steps I decided to follow this guy's advice and left the battery in.....one less item to possibly foul up. I don't know if it made it any faster (first time to open my phone, so nothing to compare it to) but I can say that my phone is charging for the first time in 6 months :D
Jennifer -
BEFORE YOU START:
1) This is doable but not easy, quick or without risk.
2) If this is your 1st time, the whole process can take >2 hours (half of it reading this fixit manual and notes, which I highly recommend!)
3) I highly recommend placing a large, thin clean white cloth on the table. This prevents screws from rolling around and you will clearly see anything falling out.
4) If you have them, use tight surgical (latex) gloves. This prevents you from greasing up contacts.
5) Have e.g. a big old egg box ready, so you can place the screws in order (and maybe write step/screw size on the side).
6) I bought my display from "Generic" on Amazon ($20.36). Screen works fine and tools were ok but not great (screw drivers do not withstand force needed to unscrew some).
7) I had my own 2mm Phillips screw driver and a 2.4mm flat (for the big screws).
8) Have a nice cold beer by your side! Good luck!
superedu111 - crwdns2934203:0crwdne2934203:0
Sounds like this comment relates to a screen replacement, not a rear panel replacement. No way a rear panel replacement would take 2 hours - can be done in 2 minutes!
Jonathan Deamer -
I was paranoid about stripping the pentalobes - I used the ifixit pentalobe screwdriver TOGETHER with a layer of Glad Wrap (cling film or saran wrap for the non-Aussies) over the pentalobe holes - absolutely no problems. Guess it helps the driver head gain purchase?
Anyway hat tip to this guy:
http://modmyi.com/forums/hardware/806092...
jimforbes - crwdns2934203:0crwdne2934203:0
It's also called glad wrap in the US as well. :)
Scorppio500 Webmaster -
After seeing the comments about trouble finding the carrier, I shut down the phone, did a soft reset (by holding the power and home buttons until it started and then shut down and stayed off), and removed the SIM. After the repair, I replaced the SIM and plugged it in to the charger. It started up and found the carrier (Verizon, as it happens) immediately. I would guess that only the soft reset made a difference, but I did both.
DavidLewis - crwdns2934203:0crwdne2934203:0
Thank you David, will I need to reload operating system if I replace thr logic board? I'm hoping to use a 32gb boards from a locked but working phone to place in my 8gb device. Thanks for your advice,
Sharif
Sharif Bagnulo -
Marv - crwdns2934203:0crwdne2934203:0
Here's a little vacuum trick for anything small: put nylons/panty hose over the end of the hose and then you don't have to dig thru the bag contents.
paul -
Marv you a first class pleb! Please don't try and fix anything again. Tool
ticklejahfancy -
It's clear who's at fault here, Marv.
It's as clear as the day has long legs. It's your Mom's fault.
Milfs who make earth-tone carpet choices, are more likely to twerk, than tweek.
And as far as trimmin the hedges are concerned, she's more likely to float a turd in the punchbowl,
than to give you your inch.
I know you think I'm crazy. But everyone else agrees. We all politely try to the other way...
Your cuck stops here. We'll not near me, go over there...
Nathan Brazil -
my screws are stipped and i am going though the front glass to get to the logic board could some one give me a guide on how to get to the board please... thanks
Caleb Croft - crwdns2934203:0crwdne2934203:0
all you need to do is remove the clip over the wifi antenna and the one that actually attaches the wifi antenna to the iphone two steps to do this job...
Ray Leahy - crwdns2934203:0crwdne2934203:0
The physical battery replacement went off without a hitch, and saw that the phone had no network connection, but also had no way to unlock. The slide lock said "Slide for Emergency Call" over my custom wallpaper and sliding would give the passcode screen, but it would reject the 6 digit passcode (it would buzz and go dark after the 4th digit, re-awakening and putting in the last 2 would indicate bad passcode). Very frustrating! I get it into recovery mode and convinced iTunes to "update" the OS, but it still didn't let me in. I performed a restore to fully factory reset the phone, and it worked! Sort of... the start screen kept being replaced by "Temperature - phone needs to cool down" but it's cold. Temp sensor is on the battery and returning to old battery fixed it. New battery is bad, and phone is wiped. Fun night.
I'm going to guess that disabling the password might save you from a similar fate. So, I'll suggest BEFORE YOU START, backup your phone and disable the passcode. Good luck.
Ian Epperson - crwdns2934203:0crwdne2934203:0
Same here.. Going through that terrible night myself! Guess you had to return your battery right?
Nuno Alves -
Is it possible to replace front glass only? If so, please provide a manuel
Iva - crwdns2934203:0crwdne2934203:0
Yes, it is. But it's very difficult and risky. Forget it... Have a look here: https://youtu.be/L_kCY05jR10
Jiri Altman -
I didn’t find this particularly difficult, even though I’m pretty inexperienced at this sort of work. I watched the video overview to get me going and then followed the steps in the guide. My tips would be to keep the screws and parts organised as you dismantle, and ensure you read all the reassembly tips as you go; it’s easy to skip over them. I also found using the Liberty Kit to replace the pentalobe screws was worthwhile.
Poor old Marv of Feb 2015. Suggest he sticks to chopping logs.
graemebagnall - crwdns2934203:0crwdne2934203:0
caught fire as soon as I replaced the back phone destroyed
Stuart Laurie - crwdns2934203:0crwdne2934203:0
The battery on the phone is swollen so I need to replace it but I can’t turn it on to drain the battery, what do I do?
Beetroot - crwdns2934203:0crwdne2934203:0
