Fix your power button by following the steps in this repair guide.
Note: Steps are based on this guide.
*Power off your phone before you start repairing
Remove the two small screws next to the dock connector
Use both thumbs to push the rear panel toward the top edge of the iPhone.
Carefully pull the rear panel away from the iPhone. Be careful not to break the clips that attach it to the phone.
Remove the two screws securing the battery connector to the logic board
detach the battery connector from the socket, then lift the bottom side of the connector and by placing the head of the tool in the middle of the speaker and the metal connector.
Use the head of your tool to carefully pull up the pressure contact which is located underneath the battery.
don't rip the battery connector socket on the logic board, this is an essential part of the iPhone connected by four soldered points.
Unscrew the two screws securing the dock connector cable cover.
Once completed, Remove the metal dock connector cable cover and place it on a safe area.
Use the head of your tool to remove the dock cable up from its socket on the logic board.
Once pulled up, Peel the dock connector cable off the logic board
Unplug the cellular antenna cable out from under the metal fingers attached to the logic board and place it on the same side as the doc connector cable
Take out four screws securing the cable cover to the logic board (the screws highlighted)
Use the head of your tool to take off the cable cover tabs out of their slots.
Once completed, take off the cable cover from its edge nearest the top and remove it and put it in a safe place.
Use the head of your tool to take off the camera connector to the logic board
The camera is now safe to remove, put it in a safe place
Use a paper clip to eject the sim card and put it in a safe place
Take off the five labeled connectors
Pry up the small grounding clip with the head of your tool and then remove it and put it in a safe place
Disconnect the wifi connector highlighted with the head of your tool
Peel up the piece of black tape
Remove the screw holding in the logic board
Lift the logic board from the side that has the speaker
Remove the logic board.
Take out the two screws keeping the lock button in place
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Once done, remove the power button with either tweezers or a sharp object
