iPhone 4S Headphone Jack Cable Assembly Replacement
crwdns2862623:0crwdne2862623:0
crwdns2948751:0crwdne2948751:0
    1. iPhone 4S Headphone Jack Cable Assembly Replacement, Headphone Jack Cable Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 4S Headphone Jack Cable Assembly Replacement, Headphone Jack Cable Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 4S Headphone Jack Cable Assembly Replacement, Headphone Jack Cable Assembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • In this step, be careful not to remove the headphone jack without first separating the top microphone from the upper case, as they are connected by a fragile flex cable.
      • Use a plastic opening tool to start to pry the headphone jack out of its recess in the rear case.
      • Then use the opening tool to gently peel the microphone up from the adhesive securing it to the top of the rear case.
      • Remove the headphone jack assembly from the rear case, being careful not to tear the microphone flex cable.
    2. iPhone 4S Headphone Jack Cable Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 1.6 mm Phillips screw securing the mute switch bracket to the outer case.
    3. iPhone 4S Headphone Jack Cable Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four 1.5 mm Phillips screws securing the volume button and silent switch brackets to the outer case.
    4. iPhone 4S Headphone Jack Cable Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a pair of tweezers to gently pull the silent switch bracket away from the outer case.
    5. iPhone 4S Headphone Jack Cable Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully peel the headphone jack/volume button cables off the adhesive securing them to the rear case.
      • Remove the headphone jack cable assembly from the iPhone.
Walter Galan
711,115 crwdns2915208:0crwdne2915208:0
crwdns2935297:01,203crwdne2935297:0
crwdns2942667:0crwdne2942667:0 2,107
