Apple has introduced the iPhone 16e to the iPhone 16 lineup, featuring a bigger battery, A18 chip, and more at an affordable price. REWA Tech has conducted a teardown to determine if this device is truly worth its price.
crwdns2936621:0crwdne2936621:0
The iPhone 16e weighs 166.1 grams, which is lighter than the other iPhone 16 models, and even standard for modern smartphones.
Remove the two Pentalobe screws located at the bottom of the phone.
Place the iPhone face up on a heating mat to loosen the adhesive holding the back cover in place.
Use a phone opening tool to create a gap between the back cover and the middle frame.
Insert a pick into the gap and slide it along to open the device.
Open the iPhone by swinging the back cover up
Disconnect the battery cable and wireless charging coil cable, then remove the back cover.
Disconnect the SIM holder base cable first.
Disconnect the flex cable
Remove the SIM tray
Remove front camera assembly
Remove the screws securing the rear camera
Remove the screws and take out the earpiece.
Remove the taptic engine and speaker.
Remove the motherboard screws and flip off the motherboard.
Once again, place the iPhone face down on the heating mat.
Insert a pick into the gap and slide it. Swing the screen and open it.
Use heat and separate the motherboard.
In the middle layer, the solder pads are wider, and the component distribution is less compact, which simplifies the layering process.
crwdns2935229:013crwdne2935229:0
