Refurbishing the iPhone 16 Pro screen is not just a cost-effective solution; it's often necessary when dealing with a cracked or damaged display. While many technicians find this task challenging, with the right tools and techniques, you can achieve a professional finish without cutting wires. In this guide, we'll walk you through the step-by-step process of refurbishing your iPhone 16 Pro screen, from start to finish.
crwdns2936621:0crwdne2936621:0
Refurbish iPhone 16 Pro Screen Without Cutting Wire
Verify the iPhone 16 Pro's touch and display functions.
If everything checks out, proceed to disassemble the screen.
Make sure the phone is turned off before disassembling it.
Use a Pentalobe Screwdriver to unscrew the bottom screws.
We use the REFOX RF40 iSeparator to separate the screen quickly.
Cover the front camera with a sticker to protect it from the laser machine.
Use a UV laser machine, such as the DALI K300, for treating the screen.
Select the appropriate diagram or pattern on the UV laser machine to ensure the entire screen is treated evenly.
Flip the screen and detach it from the iPhone 16 Pro.
Remove the cover from the camera.
Remove the front sensor assembly.
Ensure that the screen is aligned with the glass separating machine and push downward suction.
Using a soft pry knife, guide your way around the frame bezel with some alcohol.
Once the frame is removed, clean the adhesive residue thoroughly.
Use a protective film instead of cutting a wire, as it is easier and safer.
Remove glue/OCA residue using an electric glue remover or other methods.
Use alignment mold for precise alignment and to reduce the risk of air bubbles caused by operational errors.
Place the screen into a laminating machine to laminate it.
Transfer the screen to a debubbling chamber to remove any air bubbles that may have formed during the process.
Use an automatic glue dispenser to apply adhesive precisely and evenly. This ensures consistent bonding and reduces manual errors. Alternatively, you can apply glue manually.
Use a heat press machine to press and secure the frame.
Connect the screen with the phone and remove the sticker.
Check the screen to ensure it is working properly.
Now assemble the iPhone 16 Pro, as you have successfully refurbished it.
