iPhone 16 Pro Max Logic Board Removal
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. iPhone 16 Pro Max Logic Board Removal, Remove the earpiece speaker: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 16 Pro Max Logic Board Removal, Remove the earpiece speaker: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 16 Pro Max Logic Board Removal, Remove the earpiece speaker: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the earpiece speaker and 5G mmWave antenna press connectors.
  2. iPhone 16 Pro Max Logic Board Removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 Pro Max Logic Board Removal: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the six screws securing the earpiece speaker:
    • One 2.4 mm‑long Phillips screw
    • Three 1.3 mm‑long Phillips screws
    • One 1.6 mm‑long Phillips screw
    • One 3.3 mm‑long standoff screw
    • Standoff screws are best removed using a dedicated standoff driver or driver bit. In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  3. iPhone 16 Pro Max Logic Board Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 16 Pro Max Logic Board Removal: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 16 Pro Max Logic Board Removal: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to lift and remove the earpiece speaker.
    • You may feel some resistance near the top edge, where the speaker gasket seals against the frame. Pull the speaker out gently to release the seal.
  4. iPhone 16 Pro Max Logic Board Removal, Disconnect the logic board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 Pro Max Logic Board Removal, Disconnect the logic board: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the seven silver press connectors from the top of the logic board.
  5. iPhone 16 Pro Max Logic Board Removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 Pro Max Logic Board Removal: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the three black press connectors from the logic board.
  6. iPhone 16 Pro Max Logic Board Removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 Pro Max Logic Board Removal: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a standoff driver to remove the four screws securing the logic board:
    • Two 4.5 mm‑long screws
    • One 3.4 mm‑long screw
    • One 4.2 mm‑long screw
  7. iPhone 16 Pro Max Logic Board Removal, Display connector information: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This image shows the display connector underneath the logic board. The next two steps show how to disconnect this connector from the bottom of the logic board.
  8. iPhone 16 Pro Max Logic Board Removal, Remove the logic board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 16 Pro Max Logic Board Removal, Remove the logic board: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 16 Pro Max Logic Board Removal, Remove the logic board: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If your iPhone has a physical SIM tray, eject it before you proceed.
    • Make sure all the connectors are disconnected from the top of the logic board.
    • Insert the flat edge of an opening pick between the battery and the left edge of the logic board. Hold the pick in place with your fingers.
    • Insert the flat end of a spudger underneath the right edge of the logic board.
    • Gently pry with the spudger to lift the logic board and disconnect the display connector.
    • Don't remove the logic board yet. There's still a cable connected to the bottom side.
  9. iPhone 16 Pro Max Logic Board Removal: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 Pro Max Logic Board Removal: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the logic board over, being careful not to strain the connected cable.
    • Use the point of a spudger to pry up and disconnect the front sensor connector from the bottom side of the logic board.
  10. iPhone 16 Pro Max Logic Board Removal: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the logic board.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
297,051 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,300crwdne2935297:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 65
