iPhone 16 Pro Max Logic Board Installation
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. iPhone 16 Pro Max Logic Board Installation, Connect the front sensor cable: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the logic board so that the front sensor cable is close to its connector.
    • Align the front sensor cable connector carefully over its logic board socket.
    • Use the point of a spudger or your finger to press the connector until it clicks into place.
    • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  2. iPhone 16 Pro Max Logic Board Installation, Lay the logic board in place: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently bend all the loose press connectors out of the way so you can lay the logic board in place.
    • Lay the logic board in its recess.
  3. iPhone 16 Pro Max Logic Board Installation, Install the logic board: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You can't directly connect the display connector to the bottom of the logic board without removing the screen, but you might successfully connect it by screwing the logic board in place. Be sure to test your iPhone before you seal it up.
    • Make sure the logic board rests in place against its screw posts. The posts will properly align the board to the display connector underneath it.
  4. iPhone 16 Pro Max Logic Board Installation: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 Pro Max Logic Board Installation: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a standoff driver to install the four screws securing the logic board:
    • Two 4.5 mm‑long screws
    • One 3.4 mm‑long screw
    • One 4.2 mm‑long screw
  5. iPhone 16 Pro Max Logic Board Installation: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 Pro Max Logic Board Installation: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your finger or a spudger to press and connect the three black press connectors onto the logic board.
    • To re-attach press connectors like these, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  6. iPhone 16 Pro Max Logic Board Installation: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 Pro Max Logic Board Installation: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your finger or a spudger to press and connect the seven silver press connectors onto the logic board.
  7. iPhone 16 Pro Max Logic Board Installation, Install the earpiece speaker: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 Pro Max Logic Board Installation, Install the earpiece speaker: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Align the top edge of the earpiece speaker with the top edge of the frame.
    • Lay the earpiece speaker into its recess.
    • You may need to push the speaker towards the top edge of the frame to seat it properly.
  8. iPhone 16 Pro Max Logic Board Installation: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 16 Pro Max Logic Board Installation: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Install the six screws securing the earpiece speaker:
    • One 2.4 mm‑long Phillips screw
    • Three 1.3 mm‑long Phillips screws
    • One 1.6 mm‑long Phillips screw
    • One 3.3 mm‑long standoff screw
  9. iPhone 16 Pro Max Logic Board Installation: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your finger or a spudger to press and connect the earpiece speaker and the mmWave connectors onto the logic board.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
298.104 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.806crwdne2935297:0
crwdns2942667:0crwdne2942667:0 197
